Long 260 C dual clutch aligment tool
Jeffery Rightmire
PostPosted: Fri Aug 23, 2013 8:36 am    Post subject: Long 260 C dual clutch aligment tool Reply to specific post Reply with quote
I am looking for a clutch algnment tool for a Long
260 C tractor with a dual clutch. The pilot bearing
ID measures .670" ,and first spline is a 10 spline
that measures .955" OD and the second is a 14 spline
that measures 1.570" OD. Thanks
Bob
PostPosted: Fri Aug 23, 2013 9:15 pm    Post subject: Re: Long 260 C dual clutch aligment tool Reply to specific post Reply with quote
You don't need splines. Find a guy with a lathe and give him the ID of the pilot bearing and the ID of the splines in each plate and have him whip up a simple stepped shaft for you.
J. Schwiebert
PostPosted: Sun Aug 25, 2013 2:25 pm    Post subject: Re: Long 260 C dual clutch aligment tool Reply to specific post Reply with quote
Is this a Fiat look a like?
Traditional Farmer
PostPosted: Wed Aug 28, 2013 4:02 am    Post subject: Re: Long 260 C dual clutch aligment tool Reply to specific post Reply with quote
Import Tractor has them.
Traditional Farmer
PostPosted: Wed Aug 28, 2013 4:03 am    Post subject: Re: Long 260 C dual clutch aligment tool Reply to specific post Reply with quote
It is a Fiat tractor
Jeffery Rightmire
PostPosted: Wed Aug 28, 2013 4:05 pm    Post subject: Re: Long 260 C dual clutch aligment tool Reply to specific post Reply with quote
Not sure if its a Fiat look a like, Does import tractor have a website or phone number? thanks
Gambles
PostPosted: Wed Aug 28, 2013 6:55 pm    Post subject: Re: Long 260 C dual clutch aligment tool Reply to specific post Reply with quote
The shaft doesn't even need to be steel. Have one made from a broom/shovel handle.
J. Schwiebert
PostPosted: Thu Aug 29, 2013 4:43 pm    Post subject: Re: Long 260 C dual clutch aligment tool Reply to specific post Reply with quote
The alignment tool (Fiat clutch tool) is inserted just like any other alignment tool, however there is a collar that gos with that tool that you use to set the height of the release levers to. Also if this is a 3 cylinder you also need to set the spacing on those 3 pins. You have a phone number> J.
Roy in UK
PostPosted: Sun Sep 22, 2013 12:49 am    Post subject: Re: Long 260 C dual clutch aligment tool Reply to specific post Reply with quote
'Fiat' but built in Romania
Post new topic    Yesterday's Tractors Forum Index -> Lesser Known Classics All times are GMT - 8 Hours
