JD 3020 Rockshaft Piston Cover Leak
beas34
PostPosted: Fri Aug 23, 2013 8:47 am    Post subject: JD 3020 Rockshaft Piston Cover Leak Reply to specific post Reply with quote
This message is a reply to an archived post by beas34 on October 10, 2012 at 13:39:44.
The original subject was "JD 3020 Rockshaft Piston Cover Leak".
Took awhile to get around to this. Can anyone help with the exact location to install parts #6 and #7 on the shaft? Thanks.
Tx Jim
PostPosted: Fri Aug 23, 2013 8:58 am    Post subject: Re: JD 3020 Rockshaft Piston Cover Leak Reply to specific post Reply with quote
Evidently you didn't read my answer to your previous thread.
Parts key #6 is back-up ring & PK #7 is o-ring
beas34
PostPosted: Fri Aug 23, 2013 8:59 am    Post subject: Re: JD 3020 Rockshaft Piston Cover Leak Reply to specific post Reply with quote
shaft
Tx Jim
PostPosted: Fri Aug 23, 2013 9:04 am    Post subject: Re: JD 3020 Rockshaft Piston Cover Leak Reply to specific post Reply with quote
What shaft are you referring to?
beas34
PostPosted: Fri Aug 23, 2013 9:06 am    Post subject: Re: JD 3020 Rockshaft Piston Cover Leak Reply to specific post Reply with quote
Jim- I read your previous post. I tried to post a pic of the shaft and the parts. Does the O-ring and back up ring go all the way forward to the head of the shaft? There are two grooves in the shaft causing the confusion. I could email you a picture.
Tx Jim
PostPosted: Fri Aug 23, 2013 9:10 am    Post subject: Re: JD 3020 Rockshaft Piston Cover Leak Reply to specific post Reply with quote
I'm fairly confident that the o-ring and back up wash fit in a groove in bushing([parts key #5)
beas34
PostPosted: Fri Aug 23, 2013 9:16 am    Post subject: Re: JD 3020 Rockshaft Piston Cover Leak Reply to specific post Reply with quote
beas34
PostPosted: Fri Aug 23, 2013 9:23 am    Post subject: Re: JD 3020 Rockshaft Piston Cover Leak Reply to specific post Reply with quote
I am referring to the shaft as part #8. So I install o-ring all the way to the head of the shaft, install the back up ring to meet the o-ring, and install #5 (which they are identifying as a "valve")? And I know this has been a pain, but I appreciate your help. Thanks.
Tx Jim
I still think(without the aid of a 3020 Service manual) that the o-ring & BU washer either go in a groove in the bushing or big nut.
beas34
PostPosted: Fri Aug 23, 2013 9:27 am    Post subject: Re: JD 3020 Rockshaft Piston Cover Leak Reply to specific post Reply with quote
Ok. Thanks, Jim.
Tx Jim
PostPosted: Fri Aug 23, 2013 10:43 am    Post subject: Re: JD 3020 Rockshaft Piston Cover Leak Reply to specific post Reply with quote
After viewing the parts specifications for the fitting(parts key #2) I'm almost certain the o-ring & bu washer fit in a groove in bushing(parts key #5)
