water temp.
gary casey
PostPosted: Sun Aug 25, 2013 3:46 pm    Post subject: water temp. Reply to specific post Reply with quote
were do you hook up a water temp. gage on a 8n???
Bruce (VA)
PostPosted: Sun Aug 25, 2013 3:47 pm    Post subject: Re: water temp. Reply to specific post Reply with quote
Tap the head.
75 Tips
R Geiger
PostPosted: Sun Aug 25, 2013 4:07 pm    Post subject: Re: water temp. Reply to specific post Reply with quote
Youcan also get an adapter to go in the top radiator hose for the temp bulb. Me, if it is not boiling over, venting steam, it is not hot.
Bob Harvey
PostPosted: Sun Aug 25, 2013 6:13 pm    Post subject: Re: water temp. Reply to specific post Reply with quote
Easy way =
http://www.glowshiftdirect.com/38-mm-water-sender-attachment.aspx
HTH
greywolf224
PostPosted: Mon Aug 26, 2013 12:17 pm    Post subject: Re: water temp. Reply to specific post Reply with quote
Bob Harvey wrote:
(quoted from post at 19:13:42 08/25/13) Easy way =
HTH
Bob if you don't mind me adding to your response. This is the same water sender attachment that I used and it works great. Here is a few pics of it. Its soft aluminum. The threaded tap it came with was of no use to me so I drilled it out and tapped to fit my gauges bulb connector.
Ultradog MN
PostPosted: Mon Aug 26, 2013 1:11 pm    Post subject: Re: water temp. Reply to specific post Reply with quote
I agree Bruce.
Tapping the head makes for the cleanest job.
