loss of power when using my 8N
Mark Brewin
PostPosted: Mon Aug 26, 2013 7:09 am    Post subject: loss of power when using my 8N Reply to specific post Reply with quote
My tractor starts with no problem but when I start using the tractor (mowing or pulling a disc)the engine starts losing power. The RPM's fall off and it starts to sputter, but once I push in the clutch the engine runs OK. Does anyone have any idea what I could check?
R Geiger
PostPosted: Mon Aug 26, 2013 7:21 am    Post subject: Re: loss of power when using my 8N Reply to specific post Reply with quote
Check your spark plugs. you may have one or more fouled.
Roger in Iowa
PostPosted: Mon Aug 26, 2013 7:24 am    Post subject: Re: loss of power when using my 8N Reply to specific post Reply with quote
Check fuel flow. Remove plug in bottom carb. Should have a nice steady stream. Load takes more fuel so it will idle nice, but have trouble when demand is for more fuel.
HCooke
PostPosted: Mon Aug 26, 2013 7:32 am    Post subject: Re: loss of power when using my 8N Reply to specific post Reply with quote
Or loose or bad wire.
Bruce (VA)
PostPosted: Mon Aug 26, 2013 8:30 am    Post subject: Re: loss of power when using my 8N Reply to specific post Reply with quote
6v or 12v?
Front or side distributor?
When is the last time you replaced the points, plugs, condenser, rotor & cap & checked the timing? (tip # 40)
75 Tips
russb wa
PostPosted: Mon Aug 26, 2013 11:12 am    Post subject: Re: loss of power when using my 8N Reply to specific post Reply with quote
Yep, my money is on fuel supply.
I had the same problem. Evelyn would run ok at 3/4 but not full throttle.
Leaves in the sediment bowl and elbow filter at carb.
Ultradog MN
PostPosted: Mon Aug 26, 2013 1:14 pm    Post subject: Re: loss of power when using my 8N Reply to specific post Reply with quote
X2
JoePilot
PostPosted: Mon Aug 26, 2013 2:51 pm    Post subject: Re: loss of power when using my 8N Reply to specific post Reply with quote
yeah, check the super secret fuel screen in the carb inlet elbow. Or it could be a plugged fuel tank vent. Good luck.
Joe
