Gears for MM UB
Must Go Faster
PostPosted: Tue Aug 27, 2013 5:00 am    Post subject: Gears for MM UB Reply to specific post Reply with quote
Has anyone ever found an existing combination for faster gearing in the MM UB? Most of the MM parts books do not give a tooth count on the gears and I hate to start tearing down tractors to count teeth.
I'm looking for a 26-28% increase over std 2nd (preferred) or a 7-9% increase over std 3rd.
Custom gears can be made of course but I'm wanting to explore all options before getting out the checkbook.
Tim Yates
PostPosted: Thu Aug 29, 2013 1:54 pm    Post subject: Re: Gears for MM UB Reply to specific post Reply with quote
I can give you tooth counts if you send me an email. Go ahead and get out your check book.
TonyW.I
PostPosted: Thu Aug 29, 2013 4:53 pm    Post subject: Re: Gears for MM UB Reply to specific post Reply with quote
I was at a pull earlier this summer and a gentleman had a U that he had literally put together from parts he had laying around and we got talking about my UB he pointed his trans had a different shift pattern and said he put the fast trans in it.? He must have swapped the whole rear end? I am by no means an expert on MM tractors I just thought I"d pass the info thinking it mite help you
jd plowboy
PostPosted: Fri Aug 30, 2013 11:56 am    Post subject: Re: Gears for MM UB Reply to specific post Reply with quote
the earlier Us had a differnet shift pattern and a faster ring gear and pinion
Tim Yates
PostPosted: Sat Aug 31, 2013 4:44 pm    Post subject: Re: Gears for MM UB Reply to specific post Reply with quote
yes they have a faster ring and pinion but a slower constant mesh for the 1,3,4 gear. the same for 1st. The moline has a 3 shaft tranny where the farmalls have 2. The front constant mesh in the moline U's are the same in both shift patterns and that is the easier one to change with a custom gear but it will only effect 1 forward gear and reverse.
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
