titanium oxide coating drill bit sharpening - how to ?
jim_uny
PostPosted: Thu Aug 29, 2013 2:03 pm    Post subject: titanium oxide coating drill bit sharpening - how to ? Reply to specific post Reply with quote
i have a drill doctor 750x. can i sharpen it on
this or will it cause drill to wear out ? if no how
does one sharpen titanium bits ?
NCWayne
PostPosted: Thu Aug 29, 2013 2:38 pm    Post subject: Re: titanium oxide coating drill bit sharpening - how to ? Reply to specific post Reply with quote
The wheel on the Drill Doctor is diamone coated. That said the coating on those bits is extreemly thin so it won't effect anything regardless of what kind of wheel you use to sharpen it, be it the Drill Doctor, or a regular wheel on your bench grinder.
Don-Wi
PostPosted: Thu Aug 29, 2013 3:12 pm    Post subject: Re: titanium oxide coating drill bit sharpening - how to ? Reply to specific post Reply with quote
You'll be fine. The coating will grind off and to be honest, I doubt you'll notice any difference in the performace of the drill bit after you sharpen it.
Donovan from Wisconsin
Bret4207
PostPosted: Thu Aug 29, 2013 3:17 pm    Post subject: Re: titanium oxide coating drill bit sharpening - how to ? Reply to specific post Reply with quote
Go for it, you won't hurt anything. Most of the bits with some sort of miracle coating on them the coating is so thin it's not going to make a difference.
Owen Aaland
PostPosted: Thu Aug 29, 2013 3:25 pm    Post subject: Re: titanium oxide coating drill bit sharpening - how to ? Reply to specific post Reply with quote
The coating has already done its job. It helped the product.
