C front wheel shimmy?
Hossman
PostPosted: Fri Aug 30, 2013 2:57 pm    Post subject: C front wheel shimmy? Reply to specific post Reply with quote
Guys, When adjusting a narrow front C to remove the "hard road" shimmy would I remove the small shims under the capscrew that holds the bevel pinion gear,or would I remove the larger one between the pedestal itself and the front support? I have replaced the front wheel bearings on both wheels already for what its worth. I have been into the front end on the larger WC but not the lil C. Thanks for any help. sincerely, Hoss
Scott Schanus
PostPosted: Fri Aug 30, 2013 4:01 pm    Post subject: Re: C front wheel shimmy? Reply to specific post Reply with quote
Remove whole pesedal assembly. Rotate pesedal 180 degree and put back in place.
Dick L
PostPosted: Fri Aug 30, 2013 5:10 pm    Post subject: Re: C front wheel shimmy? Reply to specific post Reply with quote
The spindles are welded off center to the back of the shaft for a reason. Try pushing a shopping cart and keep the tire leading the swivel bolt.
chalmersbob(Pa)
PostPosted: Fri Aug 30, 2013 5:25 pm    Post subject: Re: C front wheel shimmy? Reply to specific post Reply with quote
Remove the shims from the between the front support and the pedestal, but not too many, there must be a little play in the gears. Bob
Hossman
PostPosted: Mon Sep 02, 2013 12:18 pm    Post subject: Re: C front wheel shimmy? Reply to specific post Reply with quote
Guys, thanks for the replys,sounds like I should start out with removing the large shims tween the pedestal and front support. Dick the "spin it" 180 degrees had me a little baffled to, like you said the "grocery cart" syndrome. Thanks again, Hoss
