511b lift arms
dhilbert
PostPosted: Sat Aug 31, 2013 1:52 pm    Post subject: 511b lift arms Reply to specific post Reply with quote
Update on my 511b got the lift arms working, but the go down so slow. Had the blade on the back and it takes literally 2 minutes for the arms to lower. Goes up fine. Any thoughts on the cause? Thanks, Dan
Case Nutty 1660
PostPosted: Sat Aug 31, 2013 2:09 pm    Post subject: Re: 511b lift arms Reply to specific post Reply with quote
check to movement of the control spool I have seen many times a worn roll pin in the linkage (close to the spool under fuel tank) not let the spool go to full stroke
dhilbert
PostPosted: Sun Sep 01, 2013 4:39 am    Post subject: Re: 511b lift arms Reply to specific post Reply with quote
Thanks Nutty I will check it out.
j hikemper
PostPosted: Sun Sep 01, 2013 5:45 am    Post subject: Re: 511b lift arms Reply to specific post Reply with quote
is there adjustment for drop ,,?like the dc and 800 ?, ..
Case Nutty 1660
PostPosted: Sun Sep 01, 2013 6:17 am    Post subject: Re: 511b lift arms Reply to specific post Reply with quote
not that I know of, speed is just controlled by how far you stroke the valve spool
JGarner
PostPosted: Sun Sep 01, 2013 6:32 am    Post subject: Re: 511b lift arms Reply to specific post Reply with quote
Good info from CNT 1600. As reference I just noticed on my 630 yesterday (nearly same as your 500b) that is if you just pull the lever back a little the arms go down real slow, the lever has to be all the way back against the stop for a quick drop and I didn't have anything hooked up to mine. With no load it took maybe 2-3 seconds to drop from all the way up to about level with the ground.
Jim
