2 bottom and tractor traction
bahmi
PostPosted: Sat Sep 07, 2013 4:25 am    Post subject: 2 bottom and tractor traction Reply to specific post Reply with quote
I have the Oliver 3242 2 bottom and have not used it yet. I have the Oliver 550, I know it has enough power to pull it, but will traction increase while using a 3 pt moldboard plow due to the downward pressure effect of the plow.
thanks to all
J. Schwiebert
PostPosted: Sat Sep 07, 2013 12:11 pm    Post subject: Re: 2 bottom and tractor traction Reply to specific post Reply with quote
You might need a wheel weight, What are your soil conditions? Make sure you have it set so the draft control can function.
rankrank1
PostPosted: Sun Sep 08, 2013 5:47 am    Post subject: Re: 2 bottom and tractor traction Reply to specific post Reply with quote
I am not familiar with the model number of plough that you listed, but in general a 3 point mounted plow will increase traction to the back of the tractor as compared to a tow type plow.
That was the brilliance of the Ferguson 3-pt system. Typically a tractor will need to weigh in the neighborhood of 5000 lbs to pull a traditional 2 bottom tow type plough. The 3 pt system allows a tractor that only weighs 2500 lbs to pull the same size 3-pt mounted plow. That was a big deal during WWII when steel was rationed and in short supply due to the war. In comparison 2 tractors could be built with same amount of steel to help feed the world instead of only 1 tractor. Of course later we found out the 3-pt was useful for other things too (blades, boxblades, scoops, post hole diggers, etc.)
I have no idea how your 550 will due on a tow type plough.
bahmi
PostPosted: Sun Sep 08, 2013 11:11 am    Post subject: Re: 2 bottom and tractor traction Reply to specific post Reply with quote
My soil is a medium textured sandy loam. It is not a heavy clay or a loose, coarse sand.
A friend pulled a big 2 bottom with his 2150 Deere diesel no problem and that"s 45HP.
If the 3 pt puts downward pressure on the rear wheels, seems like I should be able to chug along OK.
