1600 gas not firing
M. French
PostPosted: Sat Sep 07, 2013 2:17 pm    Post subject: 1600 gas not firing Reply to specific post Reply with quote
My 1600 gasser woke up this morning firing on only 4 cylinders. No prior problems at all. Has spark to the plugs which I replaced. No unusual mechanical noises. Still starts and runs but sounds a little to much like the other green tractors. Any ideas. This is my snow mover here in MN. so no time to waste.
rrlund
PostPosted: Sat Sep 07, 2013 2:19 pm    Post subject: Re: 1600 gas not firing Reply to specific post Reply with quote
Is the cap cracked and the spark jumping? It's happened to mine.
M.French
PostPosted: Sat Sep 07, 2013 2:50 pm    Post subject: Re: 1600 gas not firing Reply to specific post Reply with quote
When I pull the plug wire off and go to reattach I can see and here spark arcing to the plug.
rrlund
PostPosted: Sat Sep 07, 2013 4:24 pm    Post subject: Re: 1600 gas not firing Reply to specific post Reply with quote
Is it sparking at the right time though? I had one that was sparking just before it came up on compression as near as I can figure. Every now and then when I'd try to start it,it acted like it was firing just as it was starting up on compression,wanted to kick back just a little.
oliver90owner
PostPosted: Sun Sep 08, 2013 12:17 am    Post subject: Re: 1600 gas not firing Reply to specific post Reply with quote
A little help might be good. Which two pots are affected? Adjacent pots or adjacent in firing order would help, perhaps, as a start to try to narrow down the possibilities.
RAB
El Toro
PostPosted: Sun Sep 08, 2013 9:32 am    Post subject: Re: 1600 gas not firing Reply to specific post Reply with quote
Look real close inside the cap for tiny breaks as been mentioned. Hal
Tramway Guy
PostPosted: Sun Sep 08, 2013 10:15 am    Post subject: Re: 1600 gas not firing Reply to specific post Reply with quote
If adjacent cylinders, might be blown head gasket between them.
El Toro
PostPosted: Sun Sep 08, 2013 5:17 pm    Post subject: Re: 1600 gas not firing Reply to specific post Reply with quote
Do a compression check. You may not be getting fuel to those dead cylinders. Hal
M.French
PostPosted: Mon Sep 09, 2013 2:15 pm    Post subject: Re: 1600 gas not firing Reply to specific post Reply with quote
Its the second and fourth cylinder as seen from the operators seat. Have a cap and rotor on order. Will try that first.
rrlund
PostPosted: Mon Sep 09, 2013 3:13 pm    Post subject: Re: 1600 gas not firing Reply to specific post Reply with quote
For future reference,that cap and rotor are the same as an older Chevy 6 cylinder and available off the shelf at any auto parts store.
oliver90owner
PostPosted: Mon Sep 09, 2013 4:06 pm    Post subject: Re: 1600 gas not firing Reply to specific post Reply with quote
Almost certainly the cap as it is two adjacent HT outlets on the cap (3 and 5). One other possibility - the two HT leads have been swapped around.
The rotor will be good. If they fail to earth all six would be shorted.
M.French
PostPosted: Mon Sep 09, 2013 5:52 pm    Post subject: Re: 1600 gas not firing Reply to specific post Reply with quote
Thanks. Good info.
