Ih injection pump
Smokeingred
PostPosted: Thu Sep 12, 2013 6:53 pm    Post subject: Ih injection pump Reply to specific post Reply with quote
Would a injection pump off a ih 175c track loader be bigger then the stock pump on a 1066 the 175c has dt466 with rotaty pump just trying to find out if its a 10mm or 11mm
Dieseltech
PostPosted: Thu Sep 12, 2013 7:25 pm    Post subject: Re: Ih injection pump Reply to specific post Reply with quote
Most likely a 10mm head also. Look at the pump tag, 100 6A 100. The second 100 is the plunger size in MM, if it shows 110, that would be 11MM head. IH used 9 and 10MM heads from factory, the 11MM head that will fit with the head gear changed is for a Mack truck pump. I have never seen an IH model 100 pump with the 11MM from the factory, or in any late model parts list. Later engines switched to Bosch inline pumps.
Smokeingred
PostPosted: Thu Sep 12, 2013 7:42 pm    Post subject: Re: Ih injection pump Reply to specific post Reply with quote
Darn was hopeing to find a bigger stock pump
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
