late A MW pistons in mid A
rb54
PostPosted: Thu Sep 12, 2013 8:44 pm    Post subject: late A MW pistons in mid A Reply to specific post Reply with quote
I wanted to know if late A 584000 & up M&W pistons
will work in my mid A 583999 & dn. I was told this would work and that the piston is a 1/2 inch
tall and that this would only cause it to be hard
to hand start. This part doesn"t bother me because the tractor is electric start and it had hollingsworth inserts with all-fuel pistons and it was very hard to turn over with that set up because of the compression anyway. Any helps apreciated
730-LP
PostPosted: Fri Sep 13, 2013 5:47 am    Post subject: Re: late A MW pistons in mid A Reply to specific post Reply with quote
YES
rb54
PostPosted: Fri Sep 13, 2013 6:40 am    Post subject: Re: late A MW pistons in mid A Reply to specific post Reply with quote
Thank you
rb54
PostPosted: Fri Sep 13, 2013 6:59 am    Post subject: Re: late A MW pistons in mid A Reply to specific post Reply with quote
Thank you again and now that i know that these pistons will work anybody know what the compression would be. I have a stock head all rebuilt with the minimum surfacing done and stock stroke. Will this be a good combination and if it is what should my mag timing be and do I need to get the carb rejetted. I do live in New Mexico at 6000 ft elevation. The tractor will be mostly used to pull hay wagons for harvest festivals and some mild work. I ask because I had a set these pistons given to me.
John Deere G Man
PostPosted: Fri Sep 13, 2013 7:23 am    Post subject: Re: late A MW pistons in mid A Reply to specific post Reply with quote
Run 87 pump gas and you will be fine. As for the mag, same as before or advance it a little . Gonna have to hear it run, then play it by ear IMO. 7.5 to 1 comp guessing . I have the same setup but I stroked it to 7.5 and run 94 . No problems at all
jd50 puller
PostPosted: Fri Sep 13, 2013 8:19 am    Post subject: Re: late A MW pistons in mid A Reply to specific post Reply with quote
Had a set in our 47 A then realized it was blocking half the spark plug hole and you can actually see the compression ring just at the edge of hole. We changed them out for the correct style but they were hard to find. I believe the compression was somewhere around 130-140 psi. Tractor ran good but it lacked a little of the bottom end. Still pulled good from 4500-6500.
Gary41a
PostPosted: Fri Sep 13, 2013 6:24 pm    Post subject: Re: late A MW pistons in mid A Reply to specific post Reply with quote
I have a set of AP127 late A M&W pistons in a 41A. I notched the pistons where they plug the spark plug holes so the spark can reach the top OK. The tractor has been together for 3 years with no problems, except it is a hand crank and turns really hard!
I use it for pulling and under load burn avgas from the airport.
Good Luck
Gary
BushogPapa
PostPosted: Sat Sep 14, 2013 5:51 pm    Post subject: Re: late A MW pistons in mid A Reply to specific post Reply with quote
At 6,000 Ft Alt, you will NEED that 7.5:1 Comp..
That about equals the old "High Altitude" Pistons..
Ron.
toot
PostPosted: Wed Sep 18, 2013 6:52 am    Post subject: Re: late A MW pistons in mid A Reply to specific post Reply with quote
Are you interested in selling the inserts?
rb54
PostPosted: Fri Sep 20, 2013 8:06 am    Post subject: Re: late A MW pistons in mid A Reply to specific post Reply with quote
the inserts are for a standard bore
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
