560 compression
560gaspuller
PostPosted: Fri Sep 13, 2013 8:26 pm    Post subject: 560 compression Reply to specific post Reply with quote
what will my compression be with a 301 stock motor with a silver diamond head?.
High Octane
PostPosted: Sun Sep 15, 2013 5:10 pm    Post subject: Re: 560 compression Reply to specific post Reply with quote
220-260psi. port em out good. the 301 firecraters will not hit the head, but 263 firecraters will hit.
560gaspuller
PostPosted: Sun Sep 15, 2013 7:05 pm    Post subject: Re: 560 compression Reply to specific post Reply with quote
will i still be able to run pump gas?
Dblair
PostPosted: Mon Sep 16, 2013 5:44 am    Post subject: Re: 560 compression Reply to specific post Reply with quote
no it will cause piston meltdown use 110
560gaspuller
PostPosted: Tue Sep 17, 2013 4:59 am    Post subject: Re: 560 compression Reply to specific post Reply with quote
who should i have grind my cam?.
High Octane
PostPosted: Tue Sep 17, 2013 6:18 am    Post subject: Re: 560 compression Reply to specific post Reply with quote
had good luck with combine cams. the engine in the trucks were rated at 3800rpm. define pump gas,,,, 93 laced with e85 can handle pretty high cyl pressures.
560gaspuller
PostPosted: Tue Sep 17, 2013 8:36 am    Post subject: Re: 560 compression Reply to specific post Reply with quote
should i get a cam out of the motor i got the head from?. or get a combine cam? thanks
High Octane
PostPosted: Tue Sep 17, 2013 3:21 pm    Post subject: Re: 560 compression Reply to specific post Reply with quote
id use the cam thats in your 560, or the combine cam. get your truck head rebuilt, n gasket matched ported on the exhaust side. smooth out the intake ports, n under the valves, theres some casting flash that can be removed. you can port a combine head n get good results, but that truck head is a good bolt on power gain.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
