101 jr twin power
rosedale123
PostPosted: Sat Sep 14, 2013 5:10 pm    Post subject: 101 jr twin power Reply to specific post Reply with quote
I removed the moter ( everything for that matter) and am doing a "frame off restoration" of my grandpas 101jr. Put the tthottle plate back on ( it is in the exact postion it came off from - I punched marks to mate back to) , i hooked the linkage to the carb/gov back up . I moved one of the adjustments on the linkage. I move the throttle " thru" the throttle plate and notice it will not go into the twin power sector not the sector at the other end ( low idle??). it goes thru the normal sector just fine. I do not have it running yet.
Is this normal? does the tractor have to be running to get into the upper and lower sector? I know the twin power worked before I took it apart.
thank you
t martin
PostPosted: Sun Sep 15, 2013 4:56 am    Post subject: Re: 101 jr twin power Reply to specific post Reply with quote
My 101 senior and 44-6 go to full throttle pull without engine running. Something is bottoming out or binding I would suspect.
