HP to Pull a 17-Hole Grain Drill
Goto page 1, 2  Next
Fergienewbee
PostPosted: Sun Sep 15, 2013 4:13 am    Post subject: HP to Pull a 17-Hole Grain Drill Reply to specific post Reply with quote
Going to another auction next Saturday. They have a JD DBF 17-hole drill. It's a little bigger than I need, but if the price is right .... Can I pull it with my TO-30? I pull a 2-bottom plow without any trouble. I wouldn't think a drill would be any harder. Drill has rubber tires.
Larry
M Nut
PostPosted: Sun Sep 15, 2013 4:17 am    Post subject: Re: HP to Pull a 17-Hole Grain Drill Reply to specific post Reply with quote
We plant all our oats and hay crops with a 12ft grain drill pulled with an Allis Chalmers D-14. It is no load for the 32hp tractor at all.
rufus80
PostPosted: Sun Sep 15, 2013 4:36 am    Post subject: Re: HP to Pull a 17-Hole Grain Drill Reply to specific post Reply with quote
You'll have no problem pulling it. I once pulled our IH 510 18 hole grain drill with our JD MT (18hp). For over thirty years my grandfather pulled a IH 510/5100 18 hole with a JD A.
Roger in Iowa
PostPosted: Sun Sep 15, 2013 5:16 am    Post subject: Re: HP to Pull a 17-Hole Grain Drill Reply to specific post Reply with quote
Pulled a 16 hole with an 8N for years, even some hills, in no less than second gear.
JD Seller
PostPosted: Sun Sep 15, 2013 6:25 am    Post subject: Re: HP to Pull a 17-Hole Grain Drill Reply to specific post Reply with quote
Pulling the drill would not be any problem. Just make sure the drill has mechanical lift on it. THE TO-30 would not work well with a hydraulic lift drill.
DeltaRed
PostPosted: Sun Sep 15, 2013 6:35 am    Post subject: Re: HP to Pull a 17-Hole Grain Drill Reply to specific post Reply with quote
I pulled a 7x16 drill with an 8N.Worked well,plenty of power.Dad pulled an even bigger one with his 8N when I was a kid.
sd pete
PostPosted: Sun Sep 15, 2013 6:47 am    Post subject: Re: HP to Pull a 17-Hole Grain Drill Reply to specific post Reply with quote
You should be ok. I pulled a 12 foot Oliver with a 300 Farmall.
Dick L
PostPosted: Sun Sep 15, 2013 9:45 am    Post subject: Re: HP to Pull a 17-Hole Grain Drill Reply to specific post Reply with quote
I have pulled my Oliver 64 drill a coupla times with a B Allis Chalmers. Most of the time I use My Farmall C.
RodinNS
PostPosted: Sun Sep 15, 2013 3:45 pm    Post subject: Re: HP to Pull a 17-Hole Grain Drill Reply to specific post Reply with quote
I'm not familiar with that drill... I guess if it has the old style small seed box then you'll probably be alright. If it's a more modern drill like the 8300 that can carry 1/2 a ton of seed then I think you'd want to be very carefull on any kind of grade...
Rod
DiyDave
PostPosted: Sun Sep 15, 2013 5:48 pm    Post subject: Re: HP to Pull a 17-Hole Grain Drill Reply to specific post Reply with quote
amish do it with 4 horsepower!
mazemeister
PostPosted: Sun Sep 15, 2013 6:22 pm    Post subject: Re: HP to Pull a 17-Hole Grain Drill Reply to specific post Reply with quote
i've pulled a 7X21 JD 8200 behind a super C. barely know it's back there. that's level land, firm seedbed.
dmiller
PostPosted: Sun Sep 15, 2013 8:05 pm    Post subject: Re: HP to Pull a 17-Hole Grain Drill Reply to specific post Reply with quote
Planted 16 acres last year with a Farmall A and a Van Brunt FB 17 tube single disc.
Worked great.
Fergienewbee
PostPosted: Mon Sep 16, 2013 2:46 am    Post subject: Re: HP to Pull a 17-Hole Grain Drill Reply to specific post Reply with quote
Rod;
No I won't be hauling a half ton of seed. More like 30-50 pounds. I can probably plant most of my plots in 3 or 4 passes: cowpeas, oats, wheat, buckwheat, and grain sorghum and millet. If I use a planter, I figure I'll have over $100.00 just in plates. I want a drill, but it's certainly not mandatory.
Larry
RodinNS
PostPosted: Mon Sep 16, 2013 5:03 am    Post subject: Re: HP to Pull a 17-Hole Grain Drill Reply to specific post Reply with quote
I doubt you'll have a problem if that's as much seed as you're carrying. I'd just be worried with a full box if you had to deal with some steep grades.
Rod
Leroy
PostPosted: Mon Sep 16, 2013 6:16 am    Post subject: Re: HP to Pull a 17-Hole Grain Drill Reply to specific post Reply with quote
With that much only it will not feed out unless you have someone riding on the drill to keep the feeds full. At that size you need a full bushel left in the box after you are done planting and then it would be close to having some of the feeds running empty. And I wonder if that is the correct model as have never heard of that, FB yes is a common model but the letter on the front throws a person off as to what it is.
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
