ALLIS CHALMERS LOSING POWER
NORMAND
PostPosted: Mon Sep 16, 2013 8:33 am    Post subject: ALLIS CHALMERS LOSING POWER Reply to specific post Reply with quote
I HAVE A 1951 ALLIS CHALMERS WITH A BELLY MOWER ON IT. IT WAS RUNNING OK UNTIL I BROKE MY MOWER BELT. AFTER REPLACING THE BELT I DETERMINED THE OLD ONE HAD BEEN SLIPPING SO I DIDN"T REALIZE I HAD A PROBLEM. AFTER MOWING FOR ABOUT 5 MINUTES IT WILL START TO DIE AND AS SOON AS I CLUTCH IT IT IS OK. FROM THAT POINT ON I CANT ENGAGE THE MOWER DECK WITHOUT KILLING IT. IT WILL RUN BUT NOT WITH THE MOWER ON. I HAVE REPLACED THE POINTS, COIL, CLEANED THE CARBURETOR 3 TIMES, HAD AN EXHAUST LEAK SO I CHANGED THE EXHAUST/INTAKE GASKET AND THE MUFFLER HAD A LEAK AS WELL AND CHANGED IT. IT SEEMS TO BE STARVING FOR FUEL. HELP
NORMAND
PostPosted: Mon Sep 16, 2013 8:36 am    Post subject: Re: ALLIS CHALMERS LOSING POWER Reply to specific post Reply with quote
I FORGOT TO PUT ON MY POST THAT I PUT A CARB KIT IN THE CARBURETOR.
johnpop1
PostPosted: Mon Sep 16, 2013 8:41 am    Post subject: Re: ALLIS CHALMERS LOSING POWER Reply to specific post Reply with quote
Are you sure that the spindle isn't starting to seize on the deck?
Dick L
PostPosted: Mon Sep 16, 2013 10:47 am    Post subject: Re: ALLIS CHALMERS LOSING POWER Reply to specific post Reply with quote
About the same as the one below.
old
PostPosted: Mon Sep 16, 2013 1:02 pm    Post subject: Re: ALLIS CHALMERS LOSING POWER Reply to specific post Reply with quote
STOP throwing parts at it trouble shoot then parts or you can/will cause more problems.
#1 check that the blades spin freely with out the belt on.
#2 check any and all idlers and make sure they spin freely
#3 make sure with the belt off the PTO spins freely
As others have said good chance you have a mower problem not a tractor problem
