White 2-70 tank heater install
mmfun
PostPosted: Fri Sep 20, 2013 2:37 pm    Post subject: White 2-70 tank heater install Reply to specific post Reply with quote
Putting a tank heater on a diesel 2-70 where should I put it. From the lower radiator hose to the block or to the thermostat housing. Any input Thank you
Ivan Grant
PostPosted: Sat Sep 21, 2013 9:53 am    Post subject: Re: White 2-70 tank heater install Reply to specific post Reply with quote
You do not like the original heater that screws in the bottom rad hose?
mmfun
PostPosted: Sat Sep 21, 2013 10:35 am    Post subject: Re: White 2-70 tank heater install Reply to specific post Reply with quote
No this heater takes forever to heat the engine up.
Ivan Grant
PostPosted: Sat Sep 21, 2013 1:18 pm    Post subject: Re: White 2-70 tank heater install Reply to specific post Reply with quote
Yes I find that a lot of heat escapes through the rad.I have thought about doing the same,is there not a plug in the elbow where the top rad hose connects and the ather hose to to engine drain plug.
rdk
PostPosted: Sat Sep 21, 2013 7:07 pm    Post subject: Re: White 2-70 tank heater install Reply to specific post Reply with quote
If you are want fast heat this is the way to go. Inlet on the heater is hooked to bottom of thermostat housing and outlet to the block drain. This reversed from normal installation instructions. This way forces the heat into the block where it's needed. I've had my 2-70 hooked this way for 25 years. (snow blower tractor)
Ivan Grant
PostPosted: Mon Sep 23, 2013 10:07 am    Post subject: Re: White 2-70 tank heater install Reply to specific post Reply with quote
I have heard that the circulating heaters are hard on head gaskets.
Tony C.
PostPosted: Fri Sep 27, 2013 7:18 pm    Post subject: Re: White 2-70 tank heater install Reply to specific post Reply with quote
I've also heard it said that the heaters can be hard on the sleeve seals. Is there any truth to that?
