AD3 152 Head Gasket
jimybob
PostPosted: Sat Sep 21, 2013 1:11 pm    Post subject: AD3 152 Head Gasket Reply to specific post Reply with quote
Hi im rebuilding a perkins AD3 152 and after fitting new liners and pistons i have found the piston is 0.005" above the block face at TDC.??
Is this a problem or normal.?
Is there a thicker head gasket to overcome this.?
I havent refaced the block but it could of been done sometime in the past.
Welding man
PostPosted: Sun Sep 22, 2013 8:31 am    Post subject: Re: AD3 152 Head Gasket Reply to specific post Reply with quote
Spec says .001 below to .004 above. I wouldn't worry about .001. If I was worried a good smooth flat file would take care of the problem in a few seconds.
jimybob
PostPosted: Sun Sep 22, 2013 11:17 am    Post subject: Re: AD3 152 Head Gasket Reply to specific post Reply with quote
Thank you.
Can i just confirm your talking about Piston protrusion and not Liner protrusion.
The Piston is the issue.
Sorry for questioning you i want be sure before i put the head back on.
Welding man
PostPosted: Sun Sep 22, 2013 3:27 pm    Post subject: Re: AD3 152 Head Gasket Reply to specific post Reply with quote
Don't know if you can read this or not but the manual clearly states piston crown and also says new pistons sometimes have to be machined to meet that spec. I have never personally run into a set that had to be machined.Some engines do have different thicknesses of head gaskets to compensate for piston protrusion but I don't think these do.
jimybob
PostPosted: Mon Sep 23, 2013 9:51 am    Post subject: Re: AD3 152 Head Gasket Reply to specific post Reply with quote
Thanks, i have the I&T shop service manual and i cant find any details in it about that.
Im going to give it a go and see what happens.
