77 diesel crack on cylinder head
matthies
PostPosted: Sun Sep 22, 2013 11:30 am    Post subject: 77 diesel crack on cylinder head Reply to specific post Reply with quote
Is this common on these engines, first diesel oliver FIL has taken apart, and he noticed a crack by the injector on the gasket surface. thanks chris
J. Schwiebert
PostPosted: Sun Sep 22, 2013 12:04 pm    Post subject: Re: 77 diesel crack on cylinder head Reply to specific post Reply with quote
I would worry if there was NOT a crack in the head. If you look you will find more. I don't know you took the engine apart but get seats put in the head so you can set the valve recession to the correct specs. It will improving starting. More questions, post aphone number. J.
matthies
PostPosted: Sun Sep 22, 2013 6:38 pm    Post subject: Re: 77 diesel crack on cylinder head Reply to specific post Reply with quote
Thanks for the reply, I told him its common at least on the older diesels, he did a compression check and most were 175 but one had 225, 225 is what local oliver guru told him what it should be. Will pass your information to him tomorrow. chris
J. Schwiebert
PostPosted: Mon Sep 23, 2013 2:47 am    Post subject: Re: 77 diesel crack on cylinder head Reply to specific post Reply with quote
You need at least 100 pounds more compression than your 225! How did you check the compression?
matthies
PostPosted: Mon Sep 23, 2013 6:40 am    Post subject: Re: 77 diesel crack on cylinder head Reply to specific post Reply with quote
I'm sure he used a rubber tipped hand held tester. chris
J. Schwiebert
PostPosted: Mon Sep 23, 2013 6:44 am    Post subject: Re: 77 diesel crack on cylinder head Reply to specific post Reply with quote
That is not how you do a diesel! Do you have a phone number?
matthies
PostPosted: Mon Sep 23, 2013 11:57 am    Post subject: Re: 77 diesel crack on cylinder head Reply to specific post Reply with quote
I know about testing he used what he had on hand. If you want to call one 4o2 six4o oneseven0seven.
