fine vs course thread bolts
Goto page 1, 2  Next
Charlie M
PostPosted: Sun Sep 22, 2013 11:48 am    Post subject: fine vs course thread bolts Reply to specific post Reply with quote
Any advantage to a fine thread bolt over a course thread. Fine threads seem to be more difficult to find.
Dean
PostPosted: Sun Sep 22, 2013 11:51 am    Post subject: Re: fine vs course thread bolts Reply to specific post Reply with quote
All else equal, fine threaded fasteners produce more clamping force than course threaded fasteners at the same tightening torque and are less prome to self loosening.
Dean
DouginIL
PostPosted: Sun Sep 22, 2013 11:52 am    Post subject: Re: fine vs course thread bolts Reply to specific post Reply with quote
Fine threads can be torqued to higher values for a given diameter and grade of bolt.
dpendzic
that are less likely to work loose---a good lock washer on a course thread helps a lot
greygoat
PostPosted: Sun Sep 22, 2013 12:37 pm    Post subject: Re: fine vs course thread bolts Reply to specific post Reply with quote
I find fine threaded,(SAE) bolts/nuts at Menards,
(China), Home Depot, "Blains Farm-Fleet", and,
of course "Fastenal"
dpendzic
PostPosted: Sun Sep 22, 2013 1:16 pm    Post subject: Re: fine vs course thread bolts Reply to specific post Reply with quote
actually the limiting factor is the yield strength of the bolt. If you need more torque to produce the the same clamping force desired then a fine thread would not be as efficient as a course thread
60 acre hillside
PostPosted: Sun Sep 22, 2013 1:47 pm    Post subject: Re: fine vs course thread bolts Reply to specific post Reply with quote
Henry Ford loved them. I have found that proper choice of fasteners are usually used in the right places. I could never understand why Ford used fine thread on plow bolts.
Brian G. NY
PostPosted: Sun Sep 22, 2013 1:52 pm    Post subject: Re: fine vs course thread bolts Reply to specific post Reply with quote
You gotta run that by me once more dependzic!
I'm no engineer, but I think what Dean says sounds reasonable.
After all, walking up a less steep ramp gets you there the same as a steeper ramp but it's just a little easier walkin'.
MarkB_MI
For a given grade, a fine thread bolt has higher tensile strength than a coarse thread bolt. That's because the threads on a fine thread bold aren't as deep, leaving more of the bolt diameter.
Check out the table at the site below. A grade 5 1/2-13 bolt as a tensile strength of 17,000 lbs. For a grade 5 1/2-20 bolt, it's 19,200. That's why for applications requiring high tensile strength like head and main bearing bolts, fine thread fasteners are used almost exclusively.
Fastener tensile strength
36 Coupe
PostPosted: Sun Sep 22, 2013 2:00 pm    Post subject: Re: fine vs course thread bolts Reply to specific post Reply with quote
COARSE.Course is a golf course.Threads weaken a bolt.
Dean
PostPosted: Sun Sep 22, 2013 2:11 pm    Post subject: Re: fine vs course thread bolts Reply to specific post Reply with quote
Bingo.
Fine thread fasteners have less thread engagement. This is the reason that fine thread fasteners are not recommended for use in materials such as cast iron, aluminum, etc.
Dean
55deere70
PostPosted: Sun Sep 22, 2013 2:39 pm    Post subject: Re: fine vs course thread bolts Reply to specific post Reply with quote
Really? Most head bolts and main bearing bolts I've seen are coarse thread. I don't think fine thread would last long in cast iron or aluminum.
dpendzic
PostPosted: Sun Sep 22, 2013 3:24 pm    Post subject: Re: fine vs course thread bolts Reply to specific post Reply with quote
what i am trying to say is that fine thread has more threads per inch so the friction working against the torque applied is greater. However the strength of the bolt is determined by the yield strength of the steel--not the tensile strength--the limiting area is not the root diameter of the threads but a greater value A- sub t--determined by tests--and of course fine threads have a greater area than course threads so the ultimate allowed clamping force will be greater-but a slightly more torque will be required to obtain that.--In real life situations it is probably insignificant unless you have a required clamping force required. In all of NY state bridge design connection requirements it is standard to use course thread A325 7/8 diameter bolts tensioned to a load of 30000 lbs.-
The torque wrenches are calibrated each day with a load cell---sometimes load indicating flat washers are used---lock washers are never used.
Charlie M
PostPosted: Sun Sep 22, 2013 3:26 pm    Post subject: Re: fine vs course thread bolts Reply to specific post Reply with quote
I have to plead insanity on this one.
Bob
PostPosted: Sun Sep 22, 2013 3:57 pm    Post subject: Re: fine vs course thread bolts Reply to specific post Reply with quote
As an example, Cummins V8-470 and V-8 504 engines have fine- thread head bolts going into cast iron. Probably some pretty good stuff, maybe high nickel content???
Been so long since I worked on a 855 or other big Cummins I don"t remember if those bolts are course or fine.
Goto page 1, 2  Next
Page 1 of 2
