550 won't start, clicking on starter?
bahmi
PostPosted: Sun Sep 22, 2013 12:28 pm    Post subject: 550 won't start, clicking on starter? Reply to specific post Reply with quote
I had been using the 550 recently, ran good, started good.
I tried to start it today, only heard the "clicking" sound. Battery is good, I know that. Is it the gadget that sits on the starter with the 2 terminals that's acting up most likely?
Hope it's replaceable.
WGM
PostPosted: Sun Sep 22, 2013 1:17 pm    Post subject: Re: 550 won't start, clicking on starter? Reply to specific post Reply with quote
Try cleaning the battery terminals.
oliver90owner
PostPosted: Sun Sep 22, 2013 1:38 pm    Post subject: Re: 550 won't start, clicking on starter? Reply to specific post Reply with quote
Diesel or gasoline?
Diagnosis can be different.
bahmi
PostPosted: Sun Sep 22, 2013 3:03 pm    Post subject: Re: 550 won't start, clicking on starter? Reply to specific post Reply with quote
Terminals cleaned, battery in good shape. Still clicking.
Tractor is a GASSER.
J. Schwiebert
PostPosted: Sun Sep 22, 2013 3:27 pm    Post subject: Re: 550 won't start, clicking on starter? Reply to specific post Reply with quote
Spend $20.00 and get a multimeter. Check the voltage at the battery and then have someone hold the leads down at the starter. One on the connection whrer thecables attach the other one to a good ground. Have someelse try to start it and see what your voltage goes to.If the tractor still has a generator it should still be POSITIVE ground. Then report back here.
Chris Van
PostPosted: Mon Sep 23, 2013 11:47 am    Post subject: Re: 550 won't start, clicking on starter? Reply to specific post Reply with quote
bahmi wrote:
(quoted from post at 21:28:10 09/22/13) I had been using the 550 recently, ran good, started good.
Give the solenoid (yes, the gadget on top of the starter) a sharp tap with a wrench. They 'stick' sometimes and a sharp tap can get it working — not too hard though as you can dent it or worse, you can ground it if you bent the copper ground connection.
bahmi
PostPosted: Fri Sep 27, 2013 2:02 pm    Post subject: Re: 550 won't start, clicking on starter? Reply to specific post Reply with quote
Old Starter solenoid DEAD!! New solenoid inserted, ZOOM!!
