governor parts
Joe427...
PostPosted: Mon Sep 23, 2013 3:46 pm    Post subject: governor parts Reply to specific post Reply with quote
The weights and pins in my 310gas governor are very worn .(laminated weights). were can I get parts Thank you. Joe
J. Schwiebert
PostPosted: Mon Sep 23, 2013 4:01 pm    Post subject: Re: governor parts Reply to specific post Reply with quote
O. K. Your engine can have either a Hoof or a Pierce governor. You need to determine which one you have. The best(?) way to tell is what is the diameter of the shaft that the weights are on? Then we can go to the next step. You might want to sit down before you hear the price.
Jeff Gravert
PostPosted: Mon Sep 23, 2013 4:50 pm    Post subject: Re: governor parts Reply to specific post Reply with quote
If they are like the molines, the hoof have the solid and the Pierce have the laminated style. Don't know if that holds true on an oliver but it was all happening at the same time. Jeff
svehll
PostPosted: Mon Sep 23, 2013 5:28 pm    Post subject: Re: governor parts Reply to specific post Reply with quote
I have all the governor parts you need. I have NEW shaft,gear,ring,pin,weight,spider,sleeve,bearing
Call at 512-633-5014
Svehlak Tractor
