Cub Cadet 1250 question
Goto page 1, 2  Next
old
PostPosted: Tue Sep 24, 2013 7:46 am    Post subject: Cub Cadet 1250 question Reply to specific post Reply with quote
Is there a disconnect on them for the rear end. I have this 1250 with hydrostatic drive and it runs ok but will not move and I was told it may have a disconnect for the rear end
Phil B.
PostPosted: Tue Sep 24, 2013 8:20 am    Post subject: Re: Cub Cadet 1250 question Reply to specific post Reply with quote
It could be as simple as a broken spirol pin at the flexible connector on the driveshaft near the pump.
old
PostPosted: Tue Sep 24, 2013 8:27 am    Post subject: Re: Cub Cadet 1250 question Reply to specific post Reply with quote
Drive shaft is good since I had to out when I put in the replacement pump
Mark W.
PostPosted: Tue Sep 24, 2013 10:15 am    Post subject: Re: Cub Cadet 1250 question Reply to specific post Reply with quote
Is there a disengage lever on the left hand side, by your legs, to put it in neutral?
Ken Combs
PostPosted: Tue Sep 24, 2013 10:30 am    Post subject: Re: Cub Cadet 1250 question Reply to specific post Reply with quote
Some Cub Cadets had relief valves that were automatic, some had a manual relief lever. It's hard to say which you have, since so many have been worked on and/or swapped in the last 30 years.
Since you replaced the hydro maybe you remember the two valves on the top of the pump. If they had little buttons in the center, then it requires the manual relief lever/linkage. If not, it should roll when pushed, not easily, but it should move.
If you have the manual valves but no lever/linkage it won't move. There is no rear end/differential release, just the hydraulic valves.
Ken Combs
PostPosted: Tue Sep 24, 2013 10:33 am    Post subject: Re: Cub Cadet 1250 question Reply to specific post Reply with quote
here is a link to a pic of the manual type.
http://www.cubclassics.com/images/used057.jpg
old
PostPosted: Tue Sep 24, 2013 1:13 pm    Post subject: Re: Cub Cadet 1250 question Reply to specific post Reply with quote
No buttons so automatic relief valves so guess that is not where the drive problem is
TWheat
PostPosted: Tue Sep 24, 2013 4:37 pm    Post subject: Re: Cub Cadet 1250 question Reply to specific post Reply with quote
Rich, There was a dissconnect package available on the 1250, but I don't have the S# break. It would be a clutch located between the cooling fan (rear of tractor) and the double flex discs(S# 622952 and above had double rear drive discs).
The left brake/hydro return petal adjustment is different for the dissconnect package than without it. If you determine that you have the dissconnect package , I can scan and send you the page on adjusting that petal, but I don't think that is your problem.
old
PostPosted: Tue Sep 24, 2013 5:07 pm    Post subject: Re: Cub Cadet 1250 question Reply to specific post Reply with quote
No such clutch in the drive line since I had that out and back in
Old Roy
PostPosted: Tue Sep 24, 2013 9:51 pm    Post subject: Re: Cub Cadet 1250 question Reply to specific post Reply with quote
Here is a pic similar to both styls.
The one on the left looks like an automatic valve although it is actually the same as the one on right with button depressed.
If you have the buttons try bumping lightly with a small hammer to see if they maybe stuck.
I have a friend in SC that may have some for the quiet lines .. $50.00 each.
You don't suppose the cleaner you used was not "O" ring friendly ?
I will get heck for this but dextron II will work in place of the recommended Hy Tran.
Untitled URL Link
R Bedell
PostPosted: Wed Sep 25, 2013 1:54 am    Post subject: Re: Cub Cadet 1250 question Reply to specific post Reply with quote
old:
Quite often, there is a "spirol pin" that secures the Coupler to the Hydro Input Shaft. When this breaks, the drive shaft spins, but the Hydro Input Shaft does not. You have to look real close to see if this is happening. The spirol pin (aka: spring pin) is 1/4" x 1-1/2". Simply remove whats left of the old pin and tap in the new one.
Absent Minded Farmer
PostPosted: Wed Sep 25, 2013 7:09 am    Post subject: Re: Cub Cadet 1250 question Reply to specific post Reply with quote
No, the 1250 did not have a dump lever for the hydro. The hole for the missing lever should be punched in the tin under one of the fenders, behind the tire. If you would like a manual for it, you can have it.
We haven't had a Quiet-Line tractor in years. Great lawnmowers though, fairly easy to work on.
Mike
old
PostPosted: Wed Sep 25, 2013 7:16 am    Post subject: Re: Cub Cadet 1250 question Reply to specific post Reply with quote
Ya a manual might help me figure out why it will not move. My e-mail is open so we can talk about it
old
PostPosted: Wed Sep 25, 2013 7:17 am    Post subject: Re: Cub Cadet 1250 question Reply to specific post Reply with quote
All that was removed and then put back in since I have it apart from the engine back and had the whole rear end out and took the flex couplers apart and the shaft apart
Ken Combs
PostPosted: Wed Sep 25, 2013 10:42 am    Post subject: Re: Cub Cadet 1250 question Reply to specific post Reply with quote
OK, I'm confused. When you say "it won't move", does that mean when running it won't move under it's own power OR, that it won't roll when pushing.
My response about relief valves was to a 'wont roll' complaint primarily. But manual valves with the buttons depressed will result in a 'no drive' condition.
The responses about the roll pin were addressing a won't move under its' own power issue.
Unconfuse me please.
Goto page 1, 2  Next
Page 1 of 2
