gravely stops
paul n.h.
PostPosted: Fri Sep 27, 2013 6:18 pm    Post subject: gravely stops Reply to specific post Reply with quote
have a gravely gem 16 did not use for about 1 year put in fresh gas started right up runs good but when you let brake up it stalls step on brake starts right up any information would help thanks
joe csuti
PostPosted: Sat Sep 28, 2013 3:52 am    Post subject: Re: gravely stops Reply to specific post Reply with quote
Check operation of seat sw with an ohmmeter/battery powered test light,next check operation of control relay & time delay relay,you may have bad/corroded contacts in relays or one of the relays not working,if tractor stored in an outdoor shed/under tarp outside check wiring harness carefully,mice may have built a nest/chewed insulation on wires & same shorting to chassis.
paul n.h.
PostPosted: Sun Sep 29, 2013 2:36 pm    Post subject: Re: gravely stops Reply to specific post Reply with quote
checked seat switch okay do not know where to find controll relay or time relay thanks paul
