super c hydraulics
chev230
PostPosted: Sat Sep 28, 2013 4:31 pm    Post subject: super c hydraulics Reply to specific post Reply with quote
I think i have a leak but cant figure out where. my resivour gets low and i have to keep adding fluid. all the hydrualic hoses and connections are good and cant find a leak anywhere. i dont use any implements with hydraulic cylinders. the only cylinder is the one to raise and lower the fast hitch wich does not leak or seep oil. i need help to find the cause of why my resivour getting low.
Brian Schmidt
PostPosted: Sat Sep 28, 2013 4:35 pm    Post subject: Re: super c hydraulics Reply to specific post Reply with quote
Check the engine oil level. It is probably rising. The hydraulic pump will leak into the crankcase. The pump can be removed and easily rebuilt with a speedy sleeve on the shaft and a new seal on the drive shaft. The dealer can help you or you can go to a bearing supply house with the pump disassembled.
El Toro
PostPosted: Sat Sep 28, 2013 4:41 pm    Post subject: Re: super c hydraulics Reply to specific post Reply with quote
Brian covered your leak problem. Hal
dwag
PostPosted: Sat Sep 28, 2013 7:33 pm    Post subject: Re: super c hydraulics Reply to specific post Reply with quote
Simplest way would be to change alt to a 1 wire hookup by replacing voltage regulator.
IH fan
PostPosted: Sat Sep 28, 2013 8:55 pm    Post subject: Re: super c hydraulics Reply to specific post Reply with quote
Huh???????
GRAPE-DRANK
PostPosted: Sat Sep 28, 2013 9:02 pm    Post subject: Re: super c hydraulics Reply to specific post Reply with quote
I think he posted in the wrong thread......
Yep, yep, and yep. Same thing happened to me. I hear you can rebuild it. I just bought a new pump, put it on the tractor Thursday. Problem solved. I was shocked comparing the 2 pumps. The new pump has super tight tolerances. I could barely spin it by hand. Changed out the drive gear, hooked it up and worked very well. I can't get over how responsive the hydraulics are now. Pressure is outstanding.
I went the expensive route.
