jacobsen mower w/kohler k-241 eng
steve sipko
PostPosted: Sun Sep 29, 2013 6:18 pm    Post subject: jacobsen mower w/kohler k-241 eng Reply to specific post Reply with quote
i replaced ,new carb,solenoid battery etc,starter sw was 3 terminal would start an run till i let go of switch replaced sw with fits all 5 terminal also would run when turn sw let go it stops??,theres original generator/starter combo used to run replaced withnew ,need a wiring diagram?i replaced wires carefully but might have missed one,any help would be welcomed,thanks steve.
Bob
PostPosted: Sun Sep 29, 2013 8:02 pm    Post subject: Re: jacobsen mower w/kohler k-241 eng Reply to specific post Reply with quote
Well, that was interesting?????
http://www.kohlerengines.com/onlinecatalog/pdf/tp_2379.pdf
jeffcat
PostPosted: Sun Sep 29, 2013 8:15 pm    Post subject: Re: jacobsen mower w/kohler k-241 eng Reply to specific post Reply with quote
Hate to tell ya BOB but Kohler came up as Country girls.!! Some real cute ones.
shinnery
PostPosted: Sun Sep 29, 2013 9:49 pm    Post subject: Re: jacobsen mower w/kohler k-241 eng Reply to specific post Reply with quote
Intersting bass and old Dodge pick-ups. That Jack Sheep pedal tractor is fine.
shinnery
PostPosted: Sun Sep 29, 2013 9:51 pm    Post subject: Re: jacobsen mower w/kohler k-241 eng Reply to specific post Reply with quote
joe csuti
PostPosted: Mon Sep 30, 2013 3:02 am    Post subject: Re: jacobsen mower w/kohler k-241 eng Reply to specific post Reply with quote
If eng has point/mag or solid state ign,wire to eng ign on wrong terminal of ign sw & is being grounded in run position rather than the off/stop position killing eng ign.Disconnect wires on ign sw,with sw in OFF/STOP position with an ohmmeter check between sw shell/battery neg(-)and all terminals on sw,if you get a reading one one terminal,leave meter connected to same & turn sw to ON/RUN position,if meter reading disappears connect lead to eng ign to that terminal,If sw has a G terminal on it you might have to connect a jumper wire from G terminal to chassis/battery neg(-) to get a reading.Reconnect wires to battery /s/g or sol for same.
If eng has points/12v ign coil you probably have ign lead connected to wrong terminal & not provideing +12v to coil in ON/RUN position,with sw in ON/RUN position(leave battery/wire to s/g or sol for same connected to sw)with a voltmeter/12v test light check each sw terminal till you get a meter reading/light,turn sw to OFF/STOP position,if meter reading disappears/light goes out,then connect ign lead to that terminal.
For s/g wiring goto link below & wire according to what best matches/suites your needs,move mouse pointer over pic & click left mouse button to enlarge drawing.
wiring
IH2444
PostPosted: Thu Oct 03, 2013 4:48 pm    Post subject: Re: jacobsen mower w/kohler k-241 eng Reply to specific post Reply with quote
joe csuti wrote:
(quoted from post at 17:02:39 09/30/13) If eng has point/mag or solid state ign,wire to eng ign on wrong terminal of ign sw & is being grounded in run position rather than the off/stop position killing eng ign.Disconnect wires on ign sw,with sw in OFF/STOP position with an ohmmeter check between sw shell/battery neg(-)and all terminals on sw,if you get a reading one one terminal,leave meter connected to same & turn sw to ON/RUN position,if meter reading disappears connect lead to eng ign to that terminal,If sw has a G terminal on it you might have to connect a jumper wire from G terminal to chassis/battery neg(-) to get a reading.Reconnect wires to battery /s/g or sol for same.
wiring
Yep, this there are 2 types of switches. One for magneto ignition and one for 12V coil type ignition.
Bret4207
PostPosted: Fri Oct 04, 2013 3:36 am    Post subject: Re: jacobsen mower w/kohler k-241 eng Reply to specific post Reply with quote
Joe, where did you find that diagram?
joe csuti
PostPosted: Fri Oct 04, 2013 12:39 pm    Post subject: Re: jacobsen mower w/kohler k-241 eng Reply to specific post Reply with quote
I have an old briggs L head service/repair manual from 76 that my wife bought at a yard sale for $1 about 40 yrs ago(best thing she ever brought home from a yard sale)in the starter section it has posted diag for s/g & normal starters in addition to ign systems,carbs & anything you need to know about old 6-320000 series eng both cast iron/alum block,all the info you need that's missing from L head service manuals printed after 80.If I remember correctly same drawing is also posted at www.perr.com
Bret4207
PostPosted: Sat Oct 05, 2013 3:57 am    Post subject: Re: jacobsen mower w/kohler k-241 eng Reply to specific post Reply with quote
Thanks Joe, I'm a member at PERR, I'll have to take a look.
