D6D leaking around the throttle shaft
toby
PostPosted: Mon Sep 30, 2013 4:40 pm    Post subject: D6D leaking around the throttle shaft Reply to specific post Reply with quote
On the rod that controls speed I am not sure what to call it I would call it throttle shaft but think it is the governor, is leaking. I am not getting full power either. What is my best opinion on a fix.
TOby
Bob/Ont
PostPosted: Mon Sep 30, 2013 8:00 pm    Post subject: Re: D6D leaking around the throttle shaft Reply to specific post Reply with quote
I think you have a New Scroll fuel system on the dozer. The throttle shaft gets a good workout with the Decellerator. I suspect the housing is badly worn but you can check this out. That housing requires a lot of resealing compared to other governors. It's a bit of a trickery job and might be best to get the dealer to do it for you.
Later Bob
toby
PostPosted: Tue Oct 01, 2013 3:15 am    Post subject: Re: D6D leaking around the throttle shaft Reply to specific post Reply with quote
Thanks Bob just what I expected. I am going to have the pump and injectors checked while it is off.
Toby
