TD-6 crankshaft mounted hydraulic pump
Dave Schnautz
PostPosted: Fri Oct 04, 2013 9:17 am    Post subject: TD-6 crankshaft mounted hydraulic pump Reply to specific post Reply with quote
Where should I look for parts to renew the coupling at the crank shaft also the pump itself there is a shaft that connects the two that runs through the lower radiator tank. The two couplings are different the one at the crank is pretty beat up however the one at the pump looks to be two sprockets face to face held together by a double roller chain. Any comments or suggestions is greatly appreciated. Thank you
jm.
PostPosted: Fri Oct 04, 2013 4:18 pm    Post subject: Re: TD-6 crankshaft mounted hydraulic pump Reply to specific post Reply with quote
Dave a place called BAUM iron can come up with the pump end or the double chain but the recessed gear thing that is on the engine end is a tough one. Over the years I have seen lots of things cobbled up but no easy solution that I know of.
