Ford 9N stalling
eauker
PostPosted: Fri Oct 11, 2013 6:37 am    Post subject: Ford 9N stalling Reply to specific post Reply with quote
I have a ford 9N that I just replaced the Radiator and plugs/wires. It runs for around 1 hr then loses power and dies. It will then restart after some time has passed. It possibly overheated when radiator leaked out fluid but not sure. Any suggestions on where to look or what to do? Thanks
old
PostPosted: Fri Oct 11, 2013 7:32 am    Post subject: Re: Ford 9N stalling Reply to specific post Reply with quote
1 hour is the common time frame for a bad coil. When it dies check spark the moment it dies and look for a blue/white spark that jumps a 1/4 inch gap almost bet you do not have it
Royse
PostPosted: Fri Oct 11, 2013 7:06 pm    Post subject: Re: Ford 9N stalling Reply to specific post Reply with quote
Welcome to the forum.
I'm with Old, check for spark right when it dies.
If there is none, check for power at the top of the coil.
If there is good spark, check fuel flow next by removing the plug
from the bottom of the carb and letting it run into a container.
Let us know what you find.
