sickle mower
dahlin 1
PostPosted: Sun Oct 13, 2013 4:18 am    Post subject: sickle mower Reply to specific post Reply with quote
We just aquired a belly mounted sickle mower for a allis B, The holes in the back are quite large, so I was wondering if a bushing goes in there. This is a 6 ft cutting bar is there a model number for it. It has a hand lift.
Ted in NE-OH
PostPosted: Sun Oct 13, 2013 6:23 am    Post subject: Re: sickle mower Reply to specific post Reply with quote
The large holes are for adjustment, use big washers. No bushings.
dahlin 1
PostPosted: Sun Oct 13, 2013 7:51 am    Post subject: Re: sickle mower Reply to specific post Reply with quote
Thank you, I appreciate your answer. The forum is such a wealth of information. I am not new to allis chalmers but not well versed in the sickle mower.
steve(ill)
PostPosted: Sun Oct 13, 2013 2:35 pm    Post subject: Re: sickle mower Reply to specific post Reply with quote
just call it the sickle mower for the B-C tracator.
Paul from MI
PostPosted: Tue Oct 15, 2013 6:40 pm    Post subject: Re: sickle mower Reply to specific post Reply with quote
Originally there were two tapered cast spacers to level the drawbar mounting surface. Not sure they were necessary, but they came with the mower. Use washers as shims to get the drive belt tight. Leave the center brackets that bolt to the foot rest cross bar loose until you get the belt adjusted, then tighten. Good mower to use, horrible to put on&off, repair record was lousy. We kept the local welder busy with ours--I still have it.
Charlie175
PostPosted: Wed Oct 16, 2013 7:07 am    Post subject: Re: sickle mower Reply to specific post Reply with quote
I wish Allis had designed a trip for the bar if you hit something!
Mine cuts real good in 2nd unless the grass is thin and thick.
