heater for D-17 block
dirtfox
PostPosted: Sun Oct 13, 2013 9:24 am    Post subject: heater for D-17 block Reply to specific post Reply with quote
do any of you guys know if I can place a hose heater style in the lower radiator hose on a D-17. I do not see a block freeze plug anyplace. I'm trying to get it to start a little easier in winter. This one has a gas engine. Thanks ahead of time.
old
PostPosted: Sun Oct 13, 2013 10:43 am    Post subject: Re: heater for D-17 block Reply to specific post Reply with quote
No reason you could not put one in the lower hose unless there just isn't enough room to do so
JMS/.MN
PostPosted: Sun Oct 13, 2013 2:03 pm    Post subject: Re: heater for D-17 block Reply to specific post Reply with quote
Like old says....other option is a tank heater on the side of the engine. IDK of any frost plug options. Tank htr worked fine for me on multiple tractors. Hint- hard to find large wattage htrs now, so many only 850 watts. Go to a salvage yard and cut off of old cars. Fill with water, plug in, in a few seconds you can hear them cook if they"re ok. Likely to get them for the asking.
DiyDave
PostPosted: Sun Oct 13, 2013 5:07 pm    Post subject: Re: heater for D-17 block Reply to specific post Reply with quote
LH heaters work best when there is a 10-15 rise to the hose, pointing up to the motor. I had a D-19 diesel, put a tank style one on the side of the motor, from the block drain, up to the thermostat bypass hose. If you go the tank heater route, remember to mount it straight up, or it'll burn up from lack of thermosiphon flow.
Allis Dave
PostPosted: Tue Oct 15, 2013 1:48 pm    Post subject: Re: heater for D-17 block Reply to specific post Reply with quote
How about putting a magnet heater on the oil pan. That should warm the oil up and help it start better.
