no heat in 8550
Kevin A Rhodes
PostPosted: Sun Oct 13, 2013 9:59 am    Post subject: no heat in 8550 Reply to specific post Reply with quote
I"m not getting any heat in the cab of my 8550,the temp on engine is running normal and radiator is topped off .any suggestions where to start to look?
Anon
PostPosted: Sun Oct 13, 2013 12:19 pm    Post subject: Re: no heat in 8550 Reply to specific post Reply with quote
Take roof off of the cab and clean out the dust and dirt. Feel the hoses going to the heater core to see if they are as hot as the radiator hoses. Core could be clogged also.
Wisconsin Cowman
PostPosted: Sun Oct 13, 2013 4:36 pm    Post subject: Re: no heat in 8550 Reply to specific post Reply with quote
Check that the valve for the coolant isn"t shut off.
Kevin A Rhodes
PostPosted: Mon Oct 14, 2013 6:17 am    Post subject: Re: no heat in 8550 Reply to specific post Reply with quote
I"ll do both today.
JMS/.MN
PostPosted: Mon Oct 14, 2013 12:48 pm    Post subject: Re: no heat in 8550 Reply to specific post Reply with quote
And sometimes there is a shutoff on the return line as well, to keep heat from migrating.
Mark - IN.
PostPosted: Wed Oct 16, 2013 5:07 pm    Post subject: Re: no heat in 8550 Reply to specific post Reply with quote
Sometimes for a clog, can reverse the flow direction (reverse the lines) because the build is from one direction. By reversing the lines, can sometimes blow the clog out the other way. Worked for me on a very cold snowy winter day, and its easy enough to do. Give it a shot.
Good luck.
Mark
