SC sleeve dimensions?
Nebraska Kirk
PostPosted: Sun Oct 13, 2013 5:53 pm    Post subject: SC sleeve dimensions? Reply to specific post Reply with quote
Does anyone have a spare SC sleeve sitting on the shelf that could measure it for me? I would like to know length, outside diameters, as well as height and diameter of the top lip. Thanks in advance!!
Christopher Mikesell
PostPosted: Sun Oct 13, 2013 6:03 pm    Post subject: Re: SC sleeve dimensions? Reply to specific post Reply with quote
We need to know if you want the dimensions for the 1941-1952 engines or for the 1953 & 1954 engines. The 1953 & 1954 engines have the O-ring groove cut into the sleeve, and 1941-1952 engines have it cut into the block.
Nebraska Kirk
PostPosted: Sun Oct 13, 2013 6:16 pm    Post subject: Re: SC sleeve dimensions? Reply to specific post Reply with quote
The '41-'52 engine.
John Saeli
PostPosted: Mon Oct 14, 2013 4:16 am    Post subject: Re: SC sleeve dimensions? Reply to specific post Reply with quote
The 3-1/2" Sleeve is obsolete, but CASE still supplies the 3-5/8" Sleeve for the '41 - '52 engines.
BT in NE
PostPosted: Tue Oct 15, 2013 6:21 pm    Post subject: Re: SC sleeve dimensions? Reply to specific post Reply with quote
If you can give me a couple days, Kirk, I can pull a sleeve out of a spare block I have here and get the dimensions you need. BT
Nebraska Kirk
PostPosted: Wed Oct 16, 2013 1:42 pm    Post subject: Re: SC sleeve dimensions? Reply to specific post Reply with quote
Tell you what, Bill, why don't you just leave the sleeve in the block and measure the length, OD at top of sleeve and OD at bottom of sleeve with a tape measure, that will be close enough. I am trying to determine if an SC sleeve will work in a different engine I am rebuilding, I kinda think it won't, but with those 3 measurements I can be sure.
BT in NE
PostPosted: Wed Oct 16, 2013 5:17 pm    Post subject: Re: SC sleeve dimensions? Reply to specific post Reply with quote
These are rough measurements, but according to my trusty Stanley tape the length is 7 3/16, the top OD is 4 1/4, and the bottom OD is 3 7/8. If these may work, let me know and I can pull one out and clean it for better measuring. BT
Nebraska Kirk
PostPosted: Wed Oct 16, 2013 7:10 pm    Post subject: Re: SC sleeve dimensions? Reply to specific post Reply with quote
Nope, it won't work.
