Hydraulic Lift Cover
zminimoe
PostPosted: Tue Oct 15, 2013 5:16 am    Post subject: Hydraulic Lift Cover Reply to specific post Reply with quote
Does anyone know where I could find a hydraulic lift cover for a to 35. Something went wrong in mine and it busted. Will need to find out what went wrong also.
John(UK)
PostPosted: Tue Oct 15, 2013 8:11 am    Post subject: Re: Hydraulic Lift Cover Reply to specific post Reply with quote
The Lift Cover will smash if you change the Safety valve and fit the later valve which opens at a higher pressure. OR if the bolts securing the Top Cover to the transmission housing are not torqued tight enough and it will move. It will also crack if you drive too fast over rough ground and the implement bounces on the 3 point. When it bounces It will crash down and that is when the damage is done. Later tractors had a heavier Top over and worked at a higher pressure, they also had a larger Lift Cylinder John(UK)
Greg in MS
PostPosted: Wed Oct 16, 2013 9:24 am    Post subject: Re: Hydraulic Lift Cover Reply to specific post Reply with quote
There are several places that sell used parts like that. I use one in Holcomb, MS. Cemar Inc. I got a hydraulic cover there 4 or 5 years ago when mine broke. There was also a place in PA, but i dont remember then name.
zminimoe
PostPosted: Thu Oct 17, 2013 9:40 am    Post subject: Re: Hydraulic Lift Cover Reply to specific post Reply with quote
I have located a cover. $300.00 exchange.I would think thay is not a bad deal. I need to find out now why mine busted. Was running a sicle mower, want to raise it and it popped for no reason.
