White smoke out the exhaust
Goto page 1, 2  Next
Mandy74
PostPosted: Thu Oct 17, 2013 6:30 am    Post subject: White smoke out the exhaust Reply to specific post Reply with quote
I need help! I have white smoke coming out the exhaust of my JD 50. What would cause this? At first I thought white smoke means anti-freeze. But I have watched my anti-freeze levels and they have not moved after working the tractor. Also, got the tractor up to temperature and checked to see if there was any bubbles in the radiator. There was not!! Funny thing about this tractor is when you move the distributor clockwise from TDC it don't smoke as much still some white smoke but not like if the distributor is at TDC. About to pull my hair out. Thanks for all your input.
David from Kansas
PostPosted: Thu Oct 17, 2013 6:38 am    Post subject: Re: White smoke out the exhaust Reply to specific post Reply with quote
Does it still smoke white after getting good and warm?
My experience has been that white smoke = moisture in one form or another. Sometimes it can just be condensation in the engine and exhaust system but will usually clear up as the engine and components warm up to dry out the moisture. If it is consistent, it might be a serious problem.
wilamayb
What does the smoke smell like? Like ethylene glycol or more like unburned hydrocarbons?
Mandy74
PostPosted: Thu Oct 17, 2013 6:56 am    Post subject: Re: White smoke out the exhaust Reply to specific post Reply with quote
Unburned hydrocarbons.
Mandy74
PostPosted: Thu Oct 17, 2013 6:59 am    Post subject: Re: White smoke out the exhaust Reply to specific post Reply with quote
It takes it a good long time to warm up where it isn't smoking but every time I throttle up I get a big puff of white smoke.
buickanddeere
PostPosted: Thu Oct 17, 2013 7:29 am    Post subject: Re: White smoke out the exhaust Reply to specific post Reply with quote
Are the carb idle and main screws leaned back to as lean as possible without stumbling, stalling or losing power ?
How hot is operating temp? 160,180 or 195F
David G
PostPosted: Thu Oct 17, 2013 7:30 am    Post subject: Re: White smoke out the exhaust Reply to specific post Reply with quote
How cold is it out?
buickanddeere
PostPosted: Thu Oct 17, 2013 7:31 am    Post subject: Re: White smoke out the exhaust Reply to specific post Reply with quote
Coil and battery polarity ?
Mandy74
PostPosted: Thu Oct 17, 2013 7:32 am    Post subject: Re: White smoke out the exhaust Reply to specific post Reply with quote
About 67 degrees during the day and 45 at night.
Mandy74
PostPosted: Thu Oct 17, 2013 7:40 am    Post subject: Re: White smoke out the exhaust Reply to specific post Reply with quote
The idle screws are set to 1/2 turn out. Where the Poppin John told me to set it. The hottest it gets is 140F.
Mandy74
PostPosted: Thu Oct 17, 2013 7:52 am    Post subject: Re: White smoke out the exhaust Reply to specific post Reply with quote
Negative
buickanddeere
PostPosted: Thu Oct 17, 2013 8:27 am    Post subject: Re: White smoke out the exhaust Reply to specific post Reply with quote
140F Is no where near being warmed up.
195F or forget about it.
buickanddeere
PostPosted: Thu Oct 17, 2013 8:28 am    Post subject: Re: White smoke out the exhaust Reply to specific post Reply with quote
Battery - is to chassis and coil - is to the points ?
Bob Harvey
PostPosted: Thu Oct 17, 2013 8:33 am    Post subject: Re: White smoke out the exhaust Reply to specific post Reply with quote
Start it up then put some newspaper over the grill. The fan will keep it in place. Then let it warm up to 180 +. HTH
fixer2u
PostPosted: Thu Oct 17, 2013 9:21 am    Post subject: Re: White smoke out the exhaust Reply to specific post Reply with quote
There isnt a chance water got into the oil bath is there? Could be sucking in water from there when you pull the throttle as you described?
Goto page 1, 2  Next
Page 1 of 2
