john deere 620 pto
old fashioned farmer
PostPosted: Thu Oct 17, 2013 12:37 pm    Post subject: john deere 620 pto Reply to specific post Reply with quote
Working on a 620 with a pto issue. I had the pto out and inspected but didn't see any issues. What is happening is when installed the pto will not engage at all. The pedal will go over center into the engaged position but as soon as you take your foot off the pedal it springs back into neutral position. The pedal will go back into the locked "off" position. I thought that maybe it was adjusted too tight but after adjusting it all the way out to the loose side I see no difference. I appreciate the help.
--old fashioned farmer
PostPosted: Fri Oct 18, 2013 1:01 pm    Post subject: Re: john deere 620 pto Reply to specific post Reply with quote
Best way to work on these things is to adjust, check brake clearance when it is out of the tractor. Mount in large vise, adjust, then engage with 2 big screwdrivers. See manual. may be problem with linkage. Hint, line up plates and put in tractor engaged, then connect linkage. Russ
