Fred Cain 9Shank Cultvator
Volksman79
PostPosted: Fri Oct 18, 2013 7:51 am    Post subject: Fred Cain 9Shank Cultvator Reply to specific post Reply with quote
Has anyone used the Fred Cain 9 Shank cultivator on a TO30. Just wondering if it is worth buying a new one over a used Ferguson 9 Shank.
Tony in Mass.
PostPosted: Fri Oct 18, 2013 8:39 am    Post subject: Re: Fred Cain 9Shank Cultvator Reply to specific post Reply with quote
I don't know where you are, and where you shop, but in Northampton, WMass CL, someone is trying to sell a '59 TO35 with a huge bog harrow- for 1800. The harrows new would go for that retail. Like getting a free tractor. Even with work needed on the hydro pump or lift, if it is the deluxe, with live pto and hydro, it would be 3 times the machine your TO20 could ever be. The first time I used a 35, I thought I was on the star ship enterprise, instead of the Santa Maria...
Jason S.
PostPosted: Fri Oct 18, 2013 2:05 pm    Post subject: Re: Fred Cain 9Shank Cultvator Reply to specific post Reply with quote
It is just a copy of the Ferguson. It will work just fine it just may not be built as heavy as the originals.
Volksman79
PostPosted: Fri Oct 18, 2013 2:13 pm    Post subject: Re: Fred Cain 9Shank Cultvator Reply to specific post Reply with quote
Hi Tony,
I live in Lunenburg, MA I have a TO30. I will upgrade at some point but I am going to run this monster for a little while. I did find a BO-20 and I should have it by the end of next week. It is coming from MI. I would love to pick your brain some time. You seem to know a good bit about these tractors. email me and I can give you my number.
Arthur
John(UK)
PostPosted: Sat Oct 19, 2013 5:07 am    Post subject: Re: Fred Cain 9Shank Cultvator Reply to specific post Reply with quote
Just had a look at that Cultivator, looks a good tool, should work well behind your Tractor John(UK)
Volksman79
PostPosted: Sat Oct 19, 2013 4:26 pm    Post subject: Re: Fred Cain 9Shank Cultvator Reply to specific post Reply with quote
I should have it nest weekend. If I get all of the other parts I will give it a run and see what it can do.
Volksman79
I ended up getting a Ferguson bo-20 from Michigan.
John(UK)
PostPosted: Sun Oct 20, 2013 5:04 am    Post subject: Re: Fred Cain 9Shank Cultvator Reply to specific post Reply with quote
Well at least you know that one will work for you.
If you are trying to cultivate deep and you find that the cultivator is pulling in the ground and then lifting out all down the Field, you should tighten the Draft Spring adjustment, 1/2 a turn at a time until it improves and runs at a constant depth. The correct setting is you should be able to just turn the spring between you finger and thumb with the Cultivator in the raised position, make sure it is set to that first and then tighten it gradually BUT no more than 1-1/2 turns. When you have finished with the Cultivator, return the setting to finger and Thumb clearance again or you will find that the hydraulics won't be sensitive enough on Draft Control. Should the implement creep down quickly, when the engine is stopped, then there is a pressure leak and that needs repairing or you will find that you will not be able to get a constant depth, no matter what you do.If you find that the Adjuster for the Draft Spring is frozen, then you must not attempt to force it or you will twist the linkage inside. Use some heat on the adjuster Nut until it is free. If you need more info, email me.. John(UK) fergusontractors@hotmail.com
