Problems with Case IH 5120
Goto page 1, 2  Next
parttimefarmer
PostPosted: Fri Oct 18, 2013 4:24 pm    Post subject: Problems with Case IH 5120 Reply to specific post Reply with quote
After using my 5120 on a silage bagger, we went to unhook it from the bagger and it would not move. Put it in gear and it moves about an inch and stops. Also, the 3 point arms will not lift and the light next to the contol lever that is supposed to blink, does not. Nothing flashes on the dash indicating a possible issue with the powershift. Any ideas on wher to start looking for the problem? tractor has been problem free up to now.
Janicholson
PostPosted: Fri Oct 18, 2013 5:21 pm    Post subject: Re: Problems with Case IH 5120 Reply to specific post Reply with quote
Check the Hytran oil level. If full, add even more and give it a try. No guarantee but cheap. Jim
showcrop
PostPosted: Fri Oct 18, 2013 5:48 pm    Post subject: Re: Problems with Case IH 5120 Reply to specific post Reply with quote
Most likely your hyd pump has gone out. But it is worth overfilling and changing filters before pushing it onto the trailer.
oj
PostPosted: Fri Oct 18, 2013 5:58 pm    Post subject: Re: Problems with Case IH 5120 Reply to specific post Reply with quote
Do the rest of the hydraulics work?? Steering, remotes etc? If the hydraulic remotes are slow or the steering is poor, let me know, i have a similar problem which too forever to figure out... post back or email.
HydroTek
PostPosted: Fri Oct 18, 2013 6:59 pm    Post subject: Re: Problems with Case IH 5120 Reply to specific post Reply with quote
pull the RH cover off the dash to get to the relay and fuses ..be sure the relays are fully seated ..this was a common problem because of the vibration of the bagger. I sometimes thread a zip tie around the relay and socket to keep them from backing out
parttimefarmer
PostPosted: Sat Oct 19, 2013 8:25 am    Post subject: Re: Problems with Case IH 5120 Reply to specific post Reply with quote
Checked the hydraulic fluid level first thing. It is full.
parttimefarmer
PostPosted: Sat Oct 19, 2013 8:30 am    Post subject: Re: Problems with Case IH 5120 Reply to specific post Reply with quote
Pulled all fuses and relays and re-inserted them. Power steering works fine. Having someone stop by the check all the electrical switches and solenoids as he thinks the problem is with one of them. thanks for the input.
HydroTek
PostPosted: Sat Oct 19, 2013 3:08 pm    Post subject: Re: Problems with Case IH 5120 Reply to specific post Reply with quote
there are two lights on the dash for diagnostics, one on the left for four speed powershift anf on the right for shuttle ...both of these come on when you first key on?
parttimefarmer
PostPosted: Sun Oct 20, 2013 10:19 am    Post subject: Re: Problems with Case IH 5120 Reply to specific post Reply with quote
HydroTek wrote:
(quoted from post at 16:08:33 10/19/13) there are two lights on the dash for diagnostics, one on the left for four speed powershift anf on the right for shuttle ...both of these come on when you first key on?
Tracked problem down to not getting power to the fuse for the powershift. Jumping form another fuse to the powershift fuse gets the tractor to move and all gears to work. Now we need to find out why we are not getting power.
Owner's manual shows the relays for the powershift system above the left side fuse box. They are not there on my 5120. Next step is find them and check them out.
HydroTek
PostPosted: Sun Oct 20, 2013 5:13 pm    Post subject: Re: Problems with Case IH 5120 Reply to specific post Reply with quote
transmission relays on the right, just lights on the left. pull the fuse and look into the hole, sometimes the terminal will back out.
the relays are for the shuttle and interlock system. the powershift uses a clicker switch on the clutch pedal to activate that system. the other two switches are for the interlock system to energize the shuttle
Merr1
PostPosted: Tue Nov 26, 2013 7:21 am    Post subject: Re: Problems with Case IH 5120 Reply to specific post Reply with quote
My hydraulics are slow and steering is poor. Do you know the problem?
showcrop
PostPosted: Tue Nov 26, 2013 9:27 am    Post subject: Re: Problems with Case IH 5120 Reply to specific post Reply with quote
Merr1 wrote:
(quoted from post at 08:21:33 11/26/13) My hydraulics are slow and steering is poor. Do you know the problem?
If you are in a cold climate it could be weather and filter related. How long since filters have been replaced?
Merr1
PostPosted: Thu Jan 02, 2014 6:31 am    Post subject: Re: Problems with Case IH 5120 Reply to specific post Reply with quote
Checked fluid, its full. put 3 more gallons in it,
still no change. I am getting pressure from the
pump. I dont think its the pump. only 2600 hrs on
the tractor. Changed pressure switches,
solinoids,checked power on the fuses/relays, I dont
know from here. The tractor will move three feet
then its like it kicks in to nuetral, poor
hydraulics, poor steering.
showcrop
PostPosted: Thu Jan 02, 2014 6:59 am    Post subject: Re: Problems with Case IH 5120 Reply to specific post Reply with quote
Merr1 wrote:
(quoted from post at 07:31:35 01/02/14) Checked fluid, its full. put 3 more gallons in it,
oj
PostPosted: Thu Jan 02, 2014 7:08 am    Post subject: Re: Problems with Case IH 5120 Reply to specific post Reply with quote
AS showcrop says, change the filter... if it still does it, take the seat out of the cab, then on the tip of the transmission housing is a block with hydraulic lines/solenoids remove the block from the trans housing,pull the solenoids and check the o rings, then check the spools in the block, there may be one stuck... don't ask how i know.
Goto page 1, 2  Next
Page 1 of 2
