GBD energy cell removal
shollzzz
PostPosted: Sun Oct 20, 2013 8:12 pm    Post subject: GBD energy cell removal Reply to specific post Reply with quote
my 1958 MF95 (GBD) misses extremely bad on cylinders 1&6 when cold until warms up. was gonna clean up the energy cells and check the injector spray pattern to see if it helps.
how do I pull the energy cells out of my GBD tractor? I know I need to pull the plug out of the head and thread something into them, but wondering what size of thread fits so I can make a tool?
shinnery
PostPosted: Sun Oct 20, 2013 9:45 pm    Post subject: Re: GBD energy cell removal Reply to specific post Reply with quote
The I&T Manual says it is 15/16 " NEF-2. HTH
Bryce
Dieseltech
PostPosted: Mon Oct 21, 2013 3:34 am    Post subject: Re: GBD energy cell removal Reply to specific post Reply with quote
If it runs OK when warmed up I woud check compression first, energy cells may be fine. A bad cell should cause a miss when warm too.
J.Wondergem
PostPosted: Mon Oct 21, 2013 5:26 am    Post subject: Re: GBD energy cell removal Reply to specific post Reply with quote
If I remember right I read on here that plugged energy cells will start better, but maybe that only pertains to a certain tractor.
Alan K
PostPosted: Mon Oct 21, 2013 5:33 am    Post subject: Re: GBD energy cell removal Reply to specific post Reply with quote
I think someone was making the tools for removal. I will see if I can find a number for you. Do all the energy cell caps feel the same temperature when warmed up? Becareful not to burn your finger, they get warm.
Russ Schultz
PostPosted: Mon Oct 21, 2013 7:19 am    Post subject: Re: GBD energy cell removal Reply to specific post Reply with quote
I was wondering about compression too, It does have some blowby. i know soneone who bought ine of these travtors new and said they always ran rough until warmed up, but this is excessive. I know pistons are obsolete but wondering about Rings and bearings at Least? What's the compression supposed to be?
R.D.F.
PostPosted: Mon Oct 21, 2013 7:33 am    Post subject: Re: GBD energy cell removal Reply to specific post Reply with quote
We sell a tool for E-cell removal, River Dale Farms, 920 295 3278, Dale and Doug
mightymolinekid
PostPosted: Tue Oct 22, 2013 4:51 pm    Post subject: Re: GBD energy cell removal Reply to specific post Reply with quote
Pistons are not obsolete, depending on what size you need. There are many sizes still available through AGCO, along with bearings, gaskets, etc. You should be able to get an entire rebuild kit. A very common upgrade to the 4.25" bore diesels is to put G-900 pistons in. They are 4.375" standard bore.
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
