Yardnan leaf blower problem.
Lou from Wi.
PostPosted: Mon Oct 21, 2013 1:08 pm    Post subject: Yardnan leaf blower problem. Reply to specific post Reply with quote
Last summer son and I saw a advertisement on C.L at Rice lake. Fellow had 2 leaf blowers for sale. Went to Rice Lake where he had em sitting in his drive waiting for us to take a look. He fired em both up. No More then three plus started em both. Bought em with manuals at a bargain price.
Having problems this fall starting this one. Yard -man made by MTD.It's a yard-man YM 320BV 2 cycle gas Mulching Blower/Vacuum. Cleaned screen, worked for a while then wont start. Gonna clean and re- gap spark plug, will clean spark arrestor , etc, Any other suggestion not mentioned in the manual? Really a good unit if we could get it running and keep it ruining with out pull en.pull-en, pull-en . Any good workable suggestion would be appreciated. Regards, LOU & Victor.
AzPeapicker
PostPosted: Mon Oct 21, 2013 2:41 pm    Post subject: Re: Yardnan leaf blower problem. Reply to specific post Reply with quote
Lou
It could be the fuel pick up tube in the tank , or it could be the diaphragm in the carb. are stiff & not allowing them to work as a pump.
John in Az.
flakyfriends2@cox.net
guido
PostPosted: Mon Oct 21, 2013 2:53 pm    Post subject: Re: Yardnan leaf blower problem. Reply to specific post Reply with quote
Hello LOU from WI,
Most likely a fuel delivery problem. If you can adjust the carburetor screws, turn them him GENTLY seating them, then turn them out one turn each. Some carbs now have stops, yours could be one and you won't be able do it. I would check the tank filter, and fuel lines for cracks. Next would be the carburetor screen. and jet passages. Gap the plug at leas .030,
Good luck.............post back if you need more help,
Guido.
ss55
PostPosted: Mon Oct 21, 2013 3:39 pm    Post subject: Re: Yardnan leaf blower problem. Reply to specific post Reply with quote
The fuel line inside the fuel tank can crack and suck in air. My small 2 stroke engines usually run best with a nearly full tank of fresh fuel.
Also try backing out the carb adjustment needles in, then out, then back to their original position (count the turns). Sometimes that moves dirt away from the needles. Remove the plastic adjustment limiters if necessary.
Geo-TH,In
PostPosted: Mon Oct 21, 2013 4:37 pm    Post subject: Re: Yardnan leaf blower problem. Reply to specific post Reply with quote
Lou,
The first thing I would do is pull the plug.
See if it's wet and then check for spark using a good plug resting on engine?
Sometimes flywheel rusts. One small piece of rust touching the mag and no spark. Neighbor just had that problem.
Always check for spark first.
Second put a few drops of gas inside carb and see if you get fire.
Bet those steps weren't in manual, they are in Bubba's manual. LOL
George
Bob
PostPosted: Mon Oct 21, 2013 7:40 pm    Post subject: Re: Yardnan leaf blower problem. Reply to specific post Reply with quote
Eliminate the source of the leaves (deciduous trees) in the close-to-the-house area and life will be easier! I am on a mission to do just that. SWMBO needs to be brought up to speed/educated to the scenario that no nearby deciduous trees = NO leaves, which makes our lives easier. but I can't IMAGINE you telling the Queen that!
Geo-TH,In
PostPosted: Tue Oct 22, 2013 3:39 am    Post subject: Re: Yardnan leaf blower problem. Reply to specific post Reply with quote
Bob, When the wind blows, it blows leafs in my garage. Really doesn't matter how far away the trees are.
I know how crazy this may sound, but it really works. I have two pressure washers, 2600 & 4000 psi both with rotary nozzles. They are better than any leaf blower on the market. Gets leafs out of flower beds without doing a lot of damage to flowers too. Just don't want your neighbors see you doing it. Try it, it really works well and fast. If you do it on a windy day, you can blow the leafs out of your yard back to your neighbors, which in my case is a corn field.
George
Bob
PostPosted: Tue Oct 22, 2013 8:28 am    Post subject: Re: Yardnan leaf blower problem. Reply to specific post Reply with quote
Yeah!
My yard has a hedge on three sides, and the open side faces west into an open area (cul-de-sac), and when the NW winds of fall zip the leaves from the empty lot to the west, the hedge acts like a hockey goal, trapping the leaves and making a MESS, plus the trees we have that add to it, including a HUGE, beautiful, but messy weeping birch.
Geo-TH,In
PostPosted: Tue Oct 22, 2013 9:10 am    Post subject: Re: Yardnan leaf blower problem. Reply to specific post Reply with quote
Bob, the east side of my house is a total of 78 ft. For some reason, the leafs drift like snow on that side of house. Other places, leafs collect of a deck. Like the wood is a magnet for leafs.
When the wind blows, which is does in the fall, I have leaf drifts is the same place every year.
George
Bob S.
PostPosted: Tue Oct 22, 2013 9:52 am    Post subject: Re: Yardnan leaf blower problem. Reply to specific post Reply with quote
Hey Lou,
I'm sure you will be checking all the usual things that can go wrong but when you get to the oddball stuff check the gas gap. I had a problem like yours and after checking everything, I ran a wire thru the gas cap vent, it had a flat rubber tube that allowed venting but would not allow gas to run out of the cap. The last 3/16th of the tube had fused together, I cut 1/4 in off with nail clippers and it has been running fine ever since.
Bob S.
Lou from Wi.
PostPosted: Tue Oct 22, 2013 1:23 pm    Post subject: Re: Yardnan leaf blower problem. Reply to specific post Reply with quote
Thanks to Bob S.,George Marsh,ss55, GUIDO, azpeapicker, for the helpful replies. We will try them, as of now we are trying to finish my daughters wood,then we will try all the suggestions. Thanks to you who replied to help us out, it is much appreciated.Regards,
LOU & Victor
big a
PostPosted: Thu Oct 24, 2013 7:56 pm    Post subject: Re: Yardnan leaf blower problem. Reply to specific post Reply with quote
Check the screws holding the cylinder jug to the crankcase. IIRC, they are just self tapping ones that will work loose and strip. Fought that on a few of those, never found a cost effective fix either.
