730 Carb,linkage
PostPosted: Thu Oct 24, 2013 3:38 am    Post subject: 730 Carb,linkage Reply to specific post Reply with quote
What does linkage that is on left side of (block)that connects to Carb on right side of carb do?Linkage runs from Carb back to throdele linkage
PostPosted: Thu Oct 24, 2013 2:10 pm    Post subject: Re: 730 Carb,linkage Reply to specific post Reply with quote
That was Cases way of shutting the fuel off for an anti dieseling system by pulling the butterfly completely closed upon shutdown, if it is original you will see that the idle stop pin is a coil spring and if working properly the linkage will pull the butterfly to completely closed by flexing that spring that also serves as an idle stop screw pin.
