3 phase question
Goto page 1, 2, 3  Next
WyoDave
PostPosted: Thu Oct 24, 2013 7:36 am    Post subject: 3 phase question Reply to specific post Reply with quote
I'm building a new house, near my shop. It's going to require an electrical upgrade, and my plan is to have the COOP drop a 120/208 3 phase Y, and run this to my shop, and to the new house. That way I can stay with one meter. I see a lot of things like ovens, clothes dryers, air conditioners etc... are able to run either 240 or 208. Will they just have lower output, or is it something you can select, and still get full power out of them? Is this something I'll regret? Obviously the main benefit is having 3 phase in the shop.
David
JMOR
PostPosted: Thu Oct 24, 2013 7:40 am    Post subject: Re: 3 phase question Reply to specific post Reply with quote
WyoDave wrote:
(quoted from post at 11:36:14 10/24/13) I'm building a new house, near my shop. It's going to require an electrical upgrade, and my plan is to have the COOP drop a 120/208 3 phase Y, and run this to my shop, and to the new house. That way I can stay with one meter. I see a lot of things like ovens, clothes dryers, air conditioners etc... are able to run either 240 or 208. Will they just have lower output, or is it something you can select, and still get full power out of them? Is this something I'll regret? Obviously the main benefit is having 3 phase in the shop.
David
Before you spend too much time investigating equipment, you best talk to your co-op to see if they will do what you want & what the cost to you will be. Probably going to be a surprise!
WyoDave
PostPosted: Thu Oct 24, 2013 7:45 am    Post subject: Re: 3 phase question Reply to specific post Reply with quote
It runs right by the shop to an irrigation service anyways. They just have to do the drop. I already talked to them.
David
buickanddeere
PostPosted: Thu Oct 24, 2013 7:48 am    Post subject: Re: 3 phase question Reply to specific post Reply with quote
Electric heaters operated on 208 instead of 240 will produce approx 75% of nameplate heat. 208 instead of 220v will drop output to 89% . So the operator of an electric stove or clothes dryer would never notice the difference unless operated continuous at 100%.
Single phase well pumps and AC units will usually slug along ok on 208V as manufactures make some allowances.
Ideally the house AC and well pump would be three phase 208. Motor efficiency will be much improved over the single phase versions of the same capacity .
David G
PostPosted: Thu Oct 24, 2013 7:50 am    Post subject: Re: 3 phase question Reply to specific post Reply with quote
208 is an oddball for a home, just put in the appropriate transformer and run the home on 240/120.
WyoDave
PostPosted: Thu Oct 24, 2013 8:09 am    Post subject: Re: 3 phase question Reply to specific post Reply with quote
Thanks. The only problem I might have is I found a real nice deal on an air conditioner that isn't 3 phase. It is marked 208/230v single phase. Will it work alright? I understand the benefit behind finding a 3 phase unit, but the price is right on the one I found.
David
WyoDave
PostPosted: Thu Oct 24, 2013 8:18 am    Post subject: Re: 3 phase question Reply to specific post Reply with quote
You mean use a step up transformer to feed the house panel?
David
IH2444
PostPosted: Thu Oct 24, 2013 8:52 am    Post subject: Re: 3 phase question Reply to specific post Reply with quote
Where would you get your 120V?
dr sportster
PostPosted: Thu Oct 24, 2013 8:53 am    Post subject: Re: 3 phase question Reply to specific post Reply with quote
The only thing that should be sized as 208 only is probably the hot water heater. Otherwise you may have to wait some for hot water if it is rated 240 and operated 208. In my area the power company supplies 120/208 and most things work fine [although it is changing amperage ]. The 277/480 from Public Service is really 265/460 volts . They are ripping everyone off a little . All equipment installed is rated for 277/480 and operates normally.If you google search this you can ad alot of confusion from some of the electrical websites where everyone argues about what works and what doesn't..
Allegedly manufacturers are allowing for this in appliances.
dr sportster
PostPosted: Thu Oct 24, 2013 8:56 am    Post subject: Re: 3 phase question Reply to specific post Reply with quote
Any one phase to neutral is 120. It is a 120/208 3 ph service. Single pole breaker taking one position are still 120 output.two pole and 3 pole breakers will put out the 208 voltage.
WyoDave
PostPosted: Thu Oct 24, 2013 8:58 am    Post subject: Re: 3 phase question Reply to specific post Reply with quote
Any one of the 3 hot legs would be 120. That's the easy part
David
dr sportster
PostPosted: Thu Oct 24, 2013 9:01 am    Post subject: Re: 3 phase question Reply to specific post Reply with quote
Yes it will work fine it only needs a two pole breaker to feed the receptacle where it plugs in.
WyoDave
Thanks. Gas hot water heater, so that shouldn't be a concern. I know exactly what you mean about arguing on other sites. I'm going to have a meeting with the COOP and my electrician next week, and go over the plan. Just want to sound like I know what I'm talking about a little bit in the meeting.
David
dr sportster
PostPosted: Thu Oct 24, 2013 9:06 am    Post subject: Re: 3 phase question Reply to specific post Reply with quote
Or a two pole disconnect if it is an outside unit. [I assume too much ] Maybe not a window unit.
dr sportster
PostPosted: Thu Oct 24, 2013 9:10 am    Post subject: Re: 3 phase question Reply to specific post Reply with quote
Best way to impress people in those type meetings is to wear a hard hat wrapped in tin foil with some coat hanger or welding rod antennas.They will just assume you are some type of engineer or electrical genius. Please post pics after the meeting Thanks.
Page 1 of 3
