Case 480CK IPTO
robilmichael
PostPosted: Thu Oct 24, 2013 10:31 am    Post subject: Case 480CK IPTO Reply to specific post Reply with quote
Hi, I purchased a Case 480 CK, 1970 year, with a 3 pt. and IPTO. I cannot get the IPTO to shut off and it turns at all times. The lever seems to move correctly forward and back as if it should turn on and off, but it continues to spin. Any help on what to look for would be appreciated.
Thanks.
Adirondack case guy
PostPosted: Fri Oct 25, 2013 4:26 am    Post subject: Re: Case 480CK IPTO Reply to specific post Reply with quote
you could try backing off the adjustment a bit, but,it likely has warped clutch plates in it. You will have to take it apart to check them.
Loren
robilmichael
PostPosted: Mon Oct 28, 2013 2:14 am    Post subject: Re: Case 480CK IPTO Reply to specific post Reply with quote
Hi, I use a pipe wrench and turned the PTO with the engine and PTO off and broke it free, very easily. It must have been stuck from years of non-use. The former owner said he never used the PTO. Works fine now. Thanks.
