Sealing diesel bleed off / return line?
Alan K
PostPosted: Sat Oct 26, 2013 9:47 am    Post subject: Sealing diesel bleed off / return line? Reply to specific post Reply with quote
What does anyone use for sealing the bleed off / return line on MM diesels? I was told by the diesel shop to use pipe sealing compound which worked well on 2 of the 3 that I did but still have one (number 1 cyl) that still drips. Thank you.
G1355
PostPosted: Sat Oct 26, 2013 10:30 am    Post subject: Re: Sealing diesel bleed off / return line? Reply to specific post Reply with quote
Id try teflon tape. Be pretty much the same as your pipe compound just in a role not a liquid. And its about a buck a role. We use that for all our hoses and lines always works just dont get to tight it will crack whatever your putting it on if tou get it really tight.
Kevin Moschenrose
PostPosted: Sat Oct 26, 2013 6:27 pm    Post subject: Re: Sealing diesel bleed off / return line? Reply to specific post Reply with quote
I used the tape on my 5 star and my m5 and worked well.
j hikemper
PostPosted: Sat Oct 26, 2013 6:42 pm    Post subject: Re: Sealing diesel bleed off / return line? Reply to specific post Reply with quote
Teflon tape also worx on the return lines of a Case 800 and 930...
Alan K
PostPosted: Sat Oct 26, 2013 7:28 pm    Post subject: Re: Sealing diesel bleed off / return line? Reply to specific post Reply with quote
Thank you all for your replies. I wondered about using it as well.
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
