Gaskets
Bob grimes
PostPosted: Sun Oct 27, 2013 3:08 pm    Post subject: Gaskets Reply to specific post Reply with quote
I am restoring a 620 and would like to know which, if any, gaskets i should use gasket compound on. Thanks
JRSutton
PostPosted: Sun Oct 27, 2013 3:20 pm    Post subject: Re: Gaskets Reply to specific post Reply with quote
My opinion - if it gets wets (water, oil, gas - whatever) then use it.
If it's a dry part - like shift covers, intake manifolds etc - don't bother.
D-
PostPosted: Sun Oct 27, 2013 4:01 pm    Post subject: Re: Gaskets Reply to specific post Reply with quote
Gasket compound?? If your talking about those glues, never!
Use silicone sparingly on good surhaces, a little more on rough or pitted surfaces.
LarrySTN
PostPosted: Sun Oct 27, 2013 4:39 pm    Post subject: Re: Gaskets Reply to specific post Reply with quote
I use aerosol HiTac (sp)sprayed lightly on head gaskets (both sides of gasket, on the block, on the head). This has worked very well for many years. I use a light coating of silicone on the valve cover to glue the gasket to the valve cover, setting the gasket side down on a very flat surface, place a weight on the valve cover and let it set for 24 hours or more, this makes installation of the valve cover a breeze. I do not apply anything to the other side of the valve cover gasket. This makes it easy to remove the valve cover and re-installing if anything needs attention after the first start up.
craazyhoss
PostPosted: Mon Oct 28, 2013 7:16 am    Post subject: Re: Gaskets Reply to specific post Reply with quote
When I install gaskets I use enough stiff grease to hold in place and nothing else except head gaskets and I will use copper cote spray
Bob Harvey
PostPosted: Mon Oct 28, 2013 2:53 pm    Post subject: Re: Gaskets Reply to specific post Reply with quote
I'm fairly sure that the factory used none. I agree with Larry and his approach, these are old machines and things (surfaces) deteriorate. Use any 'goop' sparingly. HTH
