Source for Moline/Jacobsen transaxle parts
R Moline
PostPosted: Tue Oct 29, 2013 6:53 am    Post subject: Source for Moline/Jacobsen transaxle parts Reply to specific post Reply with quote
Where would one locate gaskets/bearings/seals for a '63 MM garden tractor? It's the same tractor as some of the Jacobsen tractors. Thanks
Paul in MN
PostPosted: Wed Oct 30, 2013 1:08 pm    Post subject: Re: Source for Moline/Jacobsen transaxle parts Reply to specific post Reply with quote
I don't have a real good answer for a one stop shopping trip, but each bearing and seal should have a stamped part number which can be sourced from a bearing supply house. Most of these transaxles are reassembled without gaskets, but with the use of RTV. If you feel that a gasket is required to provide the correct end play on a bearing or shaft, then cut your own gasket from stock gasket material available at any auto parts supply store.
Hopefully someone has a better answer.
Paul in MN
R Moline
PostPosted: Wed Oct 30, 2013 1:11 pm    Post subject: Re: Source for Moline/Jacobsen transaxle parts Reply to specific post Reply with quote
Thanks for the reply, I have actually found a place that seems to have most everything.
Untitled URL Link
