Lift Arm Problem
Bryce Frazier
PostPosted: Mon Nov 04, 2013 2:04 pm    Post subject: Lift Arm Problem Reply to specific post Reply with quote
Hey guys it's Bryce. Many of you know I recently got my hands on a Ford 2N, I was messing around with it in the shop, and discovered an interesting problem. On the right side of the tractor, there is the link that hooks to the lift arm that adjusts the angle of the implement if there was one hooked up. On the back of the housing for this adjustment there is a small bolt that sticks out, and every time I set my three point arms all the way down, it takes a little chunk it hits the axle housing, and after doing this so many times, it has clearly worn a little indent in the housing. Anyone have a solution for this? I can get a picture if you guys would like! Thanks, Bryce
pconnie
PostPosted: Mon Nov 04, 2013 3:03 pm    Post subject: Re: Lift Arm Problem Reply to specific post Reply with quote
there should be chains that go from each side of pto cover to each arm..
Bruce (VA)
"I can get a picture if you guys would like!"
Yes please.
75 Tips
HCooke
PostPosted: Mon Nov 04, 2013 3:20 pm    Post subject: Re: Lift Arm Problem Reply to specific post Reply with quote
" On the back of the housing for this adjustment there is a small bolt that sticks out, and every time I set my three point arms all the way down, it takes a little chunk it hits the axle housing"
I have nine N series tractors and that is normal on all of them.
Bryce Frazier
PostPosted: Tue Nov 05, 2013 8:07 am    Post subject: Re: Lift Arm Problem Reply to specific post Reply with quote
Is there a way to correct the problem, or do I just not let the arms go all the way down? Thanks, Bryce
