WD45 wide front bolt holes stripped
Rance
PostPosted: Tue Nov 05, 2013 2:20 pm    Post subject: WD45 wide front bolt holes stripped Reply to specific post Reply with quote
I have a WD45, wide front with the three bolt pivot plate. The 5/8" bolt holes are stripped. Is there enough metal in that casting so that I can bore it out and tap for 3/4" bolts?
Ted in NE-OH
PostPosted: Tue Nov 05, 2013 3:19 pm    Post subject: Re: WD45 wide front bolt holes stripped Reply to specific post Reply with quote
I wonder if there is enough material that you can drill and tap a deeper hole.
Mike Groom
PostPosted: Tue Nov 05, 2013 3:47 pm    Post subject: Re: WD45 wide front bolt holes stripped Reply to specific post Reply with quote
If you don"t have enough metal to go bigger use a 5/8 helicoil,it will be just as strong as the original tapped hole.
souNdguy
PostPosted: Tue Nov 05, 2013 5:16 pm    Post subject: Re: WD45 wide front bolt holes stripped Reply to specific post Reply with quote
if there was enough meat for 3/4, I'd tap for a large pipe plug and then go back standard.
seen block decks repaired that way.
Joe Blackeby
PostPosted: Tue Nov 05, 2013 6:55 pm    Post subject: Re: WD45 wide front bolt holes stripped Reply to specific post Reply with quote
Ya, what Mike said. Cheers!
Vito
PostPosted: Tue Nov 05, 2013 7:00 pm    Post subject: Re: WD45 wide front bolt holes stripped Reply to specific post Reply with quote
Install Heli coils.I did that on one with no problems.
Vito
Albert Goerzen
PostPosted: Wed Nov 13, 2013 2:23 pm    Post subject: Re: WD45 wide front bolt holes stripped Reply to specific post Reply with quote
Heli-coils are much stronger than tapped holes in cast. Also they are invisible once installed if your going for the restored look.
