mm 403 bore size
leroy ub
PostPosted: Wed Nov 06, 2013 5:44 am    Post subject: mm 403 bore size Reply to specific post Reply with quote
what is the bigest bore u can go to and still run water in the jugs.. im wanting to use a 5.250 bore can i still run water? thanks
Dblair
PostPosted: Wed Nov 06, 2013 6:40 am    Post subject: Re: mm 403 bore size Reply to specific post Reply with quote
ask Tim Yates he'll tell you . my 403 is 4.625 bore stock .
Jeff Gravert
PostPosted: Wed Nov 06, 2013 8:13 am    Post subject: Re: mm 403 bore size Reply to specific post Reply with quote
Boring the factory jug you can go to 4.81" and still run water and have durability. 4.875" will fit in factory jug and not last very long. Any size past that you need to have the jugs resleeved. My 5.75" has water all the way through and doesnt leak a drop. Solid jugs are the only way to go for BIG sizes.
jd plowboy
PostPosted: Wed Nov 06, 2013 5:06 pm    Post subject: Re: mm 403 bore size Reply to specific post Reply with quote
you can go to 5.319 with a hd800 jug or 5.5 if you bore it but this will require machine work to the crankcase.
Lamont
PostPosted: Mon Nov 11, 2013 6:52 pm    Post subject: Re: mm 403 bore size Reply to specific post Reply with quote
Always have liked a good set of solid jugs!
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
