Portable Abrasive Blaster
Del Huebner
PostPosted: Fri Nov 08, 2013 7:27 am    Post subject: Portable Abrasive Blaster Reply to specific post Reply with quote
Is there a Portable Abrasive Blaster available for around $200 that I can use with my DeWalt 5CFM, 200PSI Air Compressor?
thdrduck
PostPosted: Fri Nov 08, 2013 7:49 am    Post subject: Re: Portable Abrasive Blaster Reply to specific post Reply with quote
Check Harbor Freight. They sell several pressure pots for under $200. I have a 100 lb unit I use for small jobs and as a loaner (much better to loan the blaster then do the blasting for them). The size of the nozzle is what determines how much air you need not the size of the pot. 5 CFM isn't much for blasting, you will be spending lots of time waiting for the compressor to catch up. You always wanted a bigger compressor anyway, didn't you?
Josh in Pa
PostPosted: Fri Nov 08, 2013 10:07 am    Post subject: Re: Portable Abrasive Blaster Reply to specific post Reply with quote
No. You will need much much more air. 20 cfm compressors struggle.
Josh
JRSutton
PostPosted: Mon Nov 11, 2013 9:22 am    Post subject: Re: Portable Abrasive Blaster Reply to specific post Reply with quote
and I'd add to that advice that when you go with a smaller nozzle - expect more clogs.
can get very frustrating.
